Video floating window
Can you make floating windows to show video feature available?
Would that be possible in some near future app update? I use the app to check my baby and it would be very helpful to be able to see live video of him in his nest all the time while using other phone’s apps at the same time.
This is possible if you own a Wyze Cam v3 Pro camera, but we are working to expand it to more cameras.
:eyes:
I don’t see it for my V3 Pro cams yet, but I do see if for the Floodlight Pro. Did you just announce which camera is next in line? Or is it already there and it just doesn’t have the same button that the FLPro has?
3rd party Android app tinyCam is capable. It has many features, but I use it mostly as a viewer in tandem with the Wyze app and v2/v3 cams.
Default is PiP. Gotta go into Developer settings to choose floating.
On the v3 Pro while in single live view, if you click on the icon to the left of the one that forces landscape it will do a floating window!
At the Android Wyze App Level, you MUST have Picture in Picture enabled for it to work.
Do this by clicking on Settings, Apps, Wyze, Picture-in-Picture, ALLOWED.
That icon looks like a square with an arrow pointing inside the square.
You can then move the live view floating window around on your android desktop.
Pretty cool.
Correct
V3 Pro on iPhone
Yep.
It’s not there (for me) on Android:
Yes, I checked the settings:
I already knew the settings were fine though because I can do it with the FLPros, just not the V3Pros. And yes, latest firmware and app.
Are you sure it’s working on Android? I’m thinking it’s only on iOS right now. Just checking if I need to report this somewhere (fix-it-friday). Can anyone with Android confirm that this works for them with a V3 Pro?
Works on my Pixel 6a, and my spouse’s Pixel 8.
The window is not resizable like that tiny cam pro video, and only one can be active at a time.
Both phones have Android 14 with security updates through Feb 5, 2024.
both running Android App 2.49.1(390)
v3 pro firmware at 4.58.11.8391 plugin version 2.49.0.12
I have three V3 Pros, and it works on all of them!
I do not own an iphone (well nothing IOS yet, but I may switch at some point).
You are definitely missing that extra icon next to the landscape rotation icon.
Try flipping your phone into landscape mode, to see if the floating window icon appears BELOW the landscape rotation icon.
I have “display over other apps” set to "Not Allowed" on our phones though.
You may have some beta bleed in that app? :slight_smile:
I stay away from beta apps/firmware, so I know that did not affect my phones/cameras.
I have to tap the screen on the iPhone to get it to show up after I get the cam in live view. Got to be fast before it goes away.
Are you on a beta app?
Carverofchoice:
It looks like you have your font/display size increased on your phone.
My V3 Pro shows SD Card all the way to Siren below the live stream.
You may want to do
Settings, display, display size and text, “RESET SETTINGS” and see if that makes a difference, although my spouse’s looks exactly like yours except hers has the floating window icon! Never mind!
Ugh, Thanks for confirming all that, that is extremely helpful. I have the exact same App, same plugin version, same firmware, & a Pixel 8 Pro with Android 14. I didn’t have the February update loaded yet so I just installed that and it didn’t make a difference either, sadly.
Despite all those things being the exact same for us, it shows up for you but doesn’t show up for me. I even went and cleared the app cache. No change. I have at least 6 V3Pros and none of them have this for some reason (I checked them all). How weird indeed. Must be some kind of bug. I’ll go check one of my other phones when I make it back downstairs.
Yes-ish…To clarify, I’m in enrolled in beta (beta tract) but at the moment both the beta tract and the production tract are using the exact same app, the latest hotfix version. but, muerte33 has the exact same app version I do right now and the exact same firmware and the exact same OS and it’s working for them. So far, the only difference I’ve noticed is that I have a Pixel 8 Pro. So it could be related to that somehow. Like I said, I’ll check one of my other Android phones in a minute and see if they show it or not. :man_shrugging:
Well, I’ll trade you a floating window icon for a non-stuttering playback on my event viewer (with “record sound” off in advanced settings)!
:slight_smile:
Update, it doesn’t show up on my Pixel 5 either.
I might need to try a non-pixel phone though. Sometimes Pixels act weird compared to all other Android devices. Otherwise, it could be something related to my account I guess. I don’t know what else the difference is.
Heh, maybe that’s the difference, maybe the floating window causes stuttering and that’s why I don’t have it? I don’t think so, but it is an interesting difference.
Same as Carverofchoice for me, No floating window available for v3 pro, but does work for floodlight pro.
Same app & firmware as Carverofchoice.
Samsung S23 Ultra, Android 14. but it does not work for other Android devices I have either (S10, Nexus 5X, Tab A7 Lite).
Maybe its just a slow rollout?
Thank you for confirming! That is helpful. Now we can really report that this isn’t an isolated incident. :+1:
Add the Battery Cam Pro as one with the feature now. Not sure if this came with the most recent firmware update, but it is there now.
I confirm that I see it for both the Battery Cam Pro and the Floodlight Pro! :+1: Just not the V3 Pro :sob:
I submitted it in Fix-it-Friday that it’s still not working for some of us:
I don’t know if it will get chosen as the high impact issue of the month, but I do know that Jason at least reports most of the stuff in there anyway.
