V3 WIndow Mount
LifeHackster did a video on the Wyze v3 Camera mount. Figured I would post it here, he praised it for how it removed the glare when window mounting the Camera.
I wish it was easier to do angles. I usually want the camera pointed slightly in one direction, such as toward the front door.
Some guys in another thread have some pretty good helpful tips on DIY solutions for angles, but I am too lazy to go through all that effort :rofl:
I agree. Just thought this was a good video. The custom one is very elaborate. Wonder if you could take Wyzes and put a longer angled extender.
As far as removing glare goes, that’s best on single-pane windows. You may see some reflection on double-pane. I mounted one on a TRIPLE pane that had blinds in between 2 of the panes, and it gets a little noisy there, lol.
So single-pane mounting is best.
That would be the highly skillful @victormaletic and one of the tutorials that was recently released.
I just got my first wyze window and am eager to try somewhere. None of my mounting spots are really perpendicular to their window and all of our windows are double pane so we will see. Lol
Hello, All.
Not many people seem interested in my window-mounted Square Tube Glare Shield to date, so I thought to provide an angle adaptor wedge for the Wyze Window Mount device. I have links to five different angle wedges, 5°, 10°, 15°, 20°, and 25°. They can be to the right or to the left by rotating it 180°. Because of the restricted geometry of the wedges, there will be some FOV (field-of-view) loss at the higher angles. The inside space if the wedge has been flared out to reduce the FOV loss.
The picture below is the bottom view of my 15° wedge. This is the window contact surface. Note how the left and right inside faces angle out from the square top opening.
The next picture is my calculation of FOV restrictions for the various wedge angles. I am waiting for a library 3D print so I can check my results.
The shallowest window wedge (5°) at high print quality requires 1 hr 32 min and 8.7 m of filament. the 25° wedge will take about 6hr 25 min and 13.4 m of filament.
A simple way to determine the wedge angle best for you, limited to ± 25° because of FOV restrictions. Picture below.
Here is the link for the protractor PDF file: Aiming Protractor.pdf
This is the live view of the camera on the aiming stand. The camera at this location can view a person from head to toe.
All linked files in this post are for you to use as you please, at no cost to you.
Wyze Window Wedge 5°.stl
Wyze Window Wedge 10°.stl
Wyze Window Wedge 15°.stl
Wyze Window Wedge 20°.stl
Wyze Window Wedge 25°.stl
Below are links to a power cord anchor and a Camera Notch Filler Plate.
The filler plate makes the camera look better if the magnetic stand is removed to reduce weight and make a nicer looking the mount.
V3 Ribbon Cord Anchor.stl
V3 3mm Base Filler Plate.stl
The second, from the top picture, is my simplified calculated results for FOV loss at the supplied wedge angles. The vertical percentage lines are really curved lines.
The four pictures below show how I arrived at FOV losses for multi-angle Square Tube Glare Shield.
Finally, I had a 45°x45° Square Tube Glare Shield library printed to check my FOV loss diagrams.
Very similar looking except for the rounded corners in the 3D printed version. The printed one is really a rounded square tube glare shield.
This last picture shows a library-printed Square Tube Glare Shield with a filler plate and power cord holder.
Till later Victor.
I got a notification on Fri about lifehacker’s video and checked it out.
I’ve been hesitant to buy any of them because shipping is the same price as the part, but I put two in the cart and it’s only a dollar more shipping for two.
Te setup I have works pretty good but it could be better , we will see, I only have two facing out windows
