Can I buy the small cable that plugs into the back of the outdoor camera and into the solar panel cable? A squirrel chewed threw mine.
Bad squirrell!
I’m not aware of any off the top of my head. Support might have access to something, so you could try asking them.
If not, I’ll tell you what I would do in your situation if there is enough cord left by where the squirrel chewed into it:
I would strip the wires, then tie them back together, then cover the whole thing up with some of this kind of silicone self-fusing tape to weather-proof it:
You can also find it in white or clear varieties.
If you aren’t pressed for time, you can often get the exact same stuff for way cheaper on Temu, but shipping can take 1-2 weeks instead of 1-2 days from Amazon.
