Outdoor cam: water proof plug to short?
Just got my outdoor cam up that I bought a few months back. It charges just fine with the standard cord but when I try to use the outdoor cord that seals the hole better it seems like it’s to short. I have to hold my thumb on it to get a good seal or it will not keep the connect. What gives?
Can I request another plug somehow or are they all a bit “to short” to properly fit
EDIT: FYI it’s on a solar panel thus why it’s plugged in all the time in a permanent location.
Did you remove the silicone port cover from the cam? You need to pull it out or it will interfere with the solar panel plug:
