I have 3 Wyze Sense motion sensors that I have been using to turn lights on/off . Until recently they have been working great but now they won’t turn lights off unless I set the ‘no motion’ time to zero minutes.
Is anyone else experiencing this issue?
I just made a thread about a similar issue here. Is this the same issue you’re facing?
Yes! Mine are doing this too. It is driving me a little nuts. Turns off the light if I set the time to 0. Anytime at all and it does not work. I have a SmartThings motion sensor that does work correctly in Alexa so I am assuming it is something to do with Wyze.
