Using 2 Locks in the same house?
Do I have to set up 2 Wyze lock hubs if I am using 2 locks in my house?
Nope, as long as they’re both close enough to the gateway, you can run both on the same one.
I have 2 locks running off a single gateway and I just stored the extra gateway in case I ever need it (maybe the first one has problems later or I move somewhere and the second lock is really far away from the first one, so I need 2 so they’ll both have a good signal).
Awesome, thanks for the quick response.
