Will two locks work on one hub or do I need a hub plugged in for each lock?
I have 3 locks plugged into one single hub and it works great. They said they will always send a hub for each lock just in case it is needed (maybe some people have a second lock too far away from the other hub to reach both places or something). I just keep the extra ones as a backup in case the first one ever breaks down or something.
You can even have totally different settings and keypads for all the locks still. ![]()
Thanks for the quick reply
Never knew about it. Thanks for sharing.
