Can 2 wise locks share a keypad and gateway?
Can 2 Wyze locks share a keypad and gateway?
Welcome to the Wyze community @mrrussell76!
You can’t currently use a keypad with two separate locks.
I believe you can use 2 locks on one gateway, but make sure that the locks are still close to the (1) gateway.
I have 2 locks on one gateway and it works fine. Just keep in mind that if the gateway disconnects from your network, both locks will be affected. One lock per keypad though.
