Is it possible to connect one keypad to two Wyze Locks and unlock both of them? I have two doors next to each other and would prefer to unlock them with only one keypad.
Hello @rcalecomte and welcome to the community.
Currently one keypad can only control one lock. There is however a Wishlist item for this can you can vote for it also.
I love this idea. I’d also like codes on the keypad assigned to subroutines. This keypad has the ability to be a HUGE feature with a little bit of programming. Who do we need to talk to?? ![]()
Just go to @WyzeJasonJ’s link and vote for it. ![]()
I JUST figured out a solution for this! Just create a rule in the wyze app. Set the rule to trigger when your first lock unlocks. Then, create an action to unlock the second lock.
Done!
Does this actually work? I will buy wyze locks today if it does since I have 2 deadbolts on one door for added security.
If you have 2 Deadbolts on one door, you can put 2 locks on it. Then setup an Automation that says: When Lock one Unlocks, Unlock Lock 2. Then setup another Automation that says: When Lock 1 Locks, then Lock Lock 2.
I just looked at the Automation for the Palm Lock and it allows for the Unlocking and Locking based on a Trigger
this would be great if you could set it to a specific key code. Ex. I have a common door that multiple people use, so I wouldn’t want MY door to unlock anytime someone opened the common door, just when my code is typed in.
