With the new update I’m not seeing a way to turn off the sound on notifications. I want the notifications but not the constant chimes that interup whatever I’m listening to. Was this feature removed???
Welcome to the Forum, @Regi! ![]()
You might want to take a peek at another topic, where a lot of this was discussed yesterday:
Additionally, it would be helpful to know which device and Android version you’re using.
I use a Google Pixel 7. Looks like I’m not the only one annoyed with the notification changes
Okay, so on stock Android it should be a pretty easy change, right?
I easily turn off all Wyze notifications on my Samsung phones.
If you want to stop the Notifications, you can simply tap on the Bell icon at the top right of the App and that will put a line across it. But that will silence all notifications from Wyze, including the popup. However, it will still log events for you.
If you want to do it on the device, on the pixel, you can tap the volume button and then select Vibrate or off. This will turn of all notification sounds on your device until you turn it back on.
I’m not looking to turn off the notifications, i want the notification sound off
That mutes the notifications, i want the notifications, i don’t want the sound.
Ok then use the second option which places your phone in silence or vibrate mode. then all notifications will still come but no sound will be made. Second option in my response above
