Thermostat offline repeatedly
Here are the two items I had to add in order to power cycle the thermostat remotely:
https://www.homedepot.com/p/Defiant-15-Amp-120-Volt-Indoor-Smart-Plug-and-Timer-Wi-Fi-Bluetooth-Single-Outlet-Powered-by-Hubspace-HPPA11AWB/315636834
The transformer has instructions for connecting with a thermostat. The only hard part was fishing the wires behind the wall from the outlet to the thermostat. I was lucky that my outlet was only 3 feet away. If you don’t think you can do that, you could run the wires outside the wall (doesn’t look good) or hire a handy person to help you. I would hate to hire a HVAC expert or electrician to do this simple job.
Hope this helps. Gary.
My solution was to just power cycle the whole furnace. I have a propane furnace which runs on 110V. I replaced the hard-wired connection with a plug and use a smart outlet that can be controlled remotely.
It works but this is really a poor job by Wyze.
Once again, I’ll wonder out loud if ANYBODY is actually DOING ANYTHING with these logs we have been submitting. Mine have been solid for a long time and suddenly one of them is dropping offline about once a week.
Log 1858092 @WyzeJasonJ
As a comparison to mine, I have firmware1.2.8 and plugin version 3.0. I only had problem once since it was installed on 9/23. I took off wall then deleted and added back on like it was new. My settings did come back in automatically.
Good luck resolving yours.
DJ
Glad to know that your experience is very different from everyone else in this thread. As has been said here many times, there is nothing any of us can do to resolve this issue. It is a weakness in the Wyze firmware, the underlying hardware or both. When the thermostat loses its session with the cloud servers, it does not attempt to reconnect. It just sits there offline until it is restarted. Only Wyze can correct this issue and they have ignored it for going on four years now.
@WyzeJasonJ
Very much agree that this has been a major fail on Wyze’ part. I’ve stopped buying their products as a result and moved on.
Landed here after, of course, loosing connectivity to my Wyze thermostat. Hoping this note may save future us some time.
I could always see the thermostat in network, device always had ‘strong’ signal. I could also ping it.
However, like everyone here, I couldn’t load UI on browser… Smells like IP conflict. A few other devices were ‘off’ as well; unavailable to log into.
From my devices list on router, I could see each device’s MAC Address and IP. I just took thermostat out of DHCP addressing and manually assigned it the IP it had attached to in the first place.
Voila, device back. I then circled back and did all the other (2) devices that were also off, a garage door and a backup server. This all happened just a little bit after I had extended guest stay at my house; I suspect and IP grab shuffle from some rouge device of theirs.
Hope this helps; cheers,
I installed a WYZE Thermostat at my recreational property in January 2025. I thought it would be nice to monitor the furnace from my home and turn the heat up before heading there.
Unfortunately, every time I returned home I got the “Device Offline” message. I had a workaround to remotely reboot the modem at the recreational property that restored connectivity 90% of the time. For the other 10%, when I returned to the recreational property I had to pull the thermostat off the wall and plug it back in.
Note that while “Offline”:
  • the thermostat continued to work and maintain the heat.
  • showed as ‘connected’ to Wi-Fi in my modem management screen
  • showed as ‘disconnected’ in the WYZE app Thermostat Device Info screen.
In June I contacted WYZE Support. They were very responsive and after exchanging a couple of emails with suggestions on changing settings (which I had already tried) they sent me a new thermostat.
Unfortunately, the new thermostat also gave the “Device Offline” message when I returned home.
In July I installed an Ecobee thermostat at my recreational property and so far it has remained online during the 3 times I returned home.
I then installed the WYZE thermostat at my home. I have been at my recreational property for the last 2 weeks and the WYZE thermostat has remained Online!
When the WYZE Thermostat was installed at my recreational property, I cannot explain why it stayed Online when we were present and only went Offline when we left. WYZE Support suggested that it may be related to “Auto Switch” - but this was turned OFF, plus it works fine when installed at my home and we are away.
My conclusion is that the WYZE thermostat is not compatible with the slower internet service at my recreational property, where I have a 25 Mbps LTE based service with high latency (>20ms ping).
Also, I have 4 OG cameras at my recreational property and they connect to the WYZE servers whether we are on site or away. The cameras must use different network software/hardware.
The Ecobee thermostat connects on the 5GHz band and maybe this helps it maintain a connection to the Ecobee servers on a high latency internet connection.
At home I have a 1.5G fiber internet service with low latency (<10ms ping) which I assume allows the WYZE thermostat to maintain a connection with the WYZE servers.
Yep, you’ve hit on what several of us in this thread believe to be the issue. Latency causes the connection from the thermostat to the Wyze cloud to hiccup and the thermostat doesn’t attempt to restore the connection. So the thermostat sits there forever offline until you reboot it … I mean kill the power and force a restart. No other Wyze device I own has this issue.
Mine does the same thing all the time!!!
Another Wyze device that just kinda sorta works as long as you dont mind occasional problems. Sigh
Will try to assign a static IP as someone else suggested and see if that helps.
Don’t get your hopes up. That didn’t help me. I’m convinced that the issue lies in the TCP/IP stack within the thermostat itself. If it loses its session with the WYZE cloud due to a hiccup in the network, it can’t or won’t reestablish the session. It’s still running and responds to pings but can’t talk to the cloud so it goes “offline”. Seems like an easy fix to me but it’s apparently priority -1000 for WYZE.
I have 2 on a mesh wifi system, one is solid as a rock the other one drops and goes offline at least once a week. I’ll try a static IP, but it’s pinned to one AP and our wifi is solid, nothing else has issues or drops so thinknthe theory of something in the TCP/IP stack to be right.
I hope that works for you. I have a strong hunch, it won’t. I tried everything and the only thing that’s worked consistently for me (and I’m not calling this a “fix”) is adding a WiFi plug and scheduling for it to restart once a day. I also schedule my Home mesh system to restart once a day.
This is the only way have gotten mine to remain online consistently.
Odd that 1 works and 1 doesn’t as they are on the same network. Have you tried swapping the thermostats to see if it is a thermostat problem or a location problem?
As indicated in my post above, my issue was my high latency internet. While others have installed smart plugs and C-wire adapters to power cycle the thermostat, I decided to buy an Ecobee thermostat that has worked with no issues for over a year.
Hi, is anyone else having trouble with their thermostat loading after the recent app update (version 3.19)? My Wyze thermostat has been working great since I got it when it first came out. Now it won’t even let me delete and reinstall it. I’ve already tried everything like powering off the thermostat and router, clearing the cache, logging out, etc. Nothing has worked. I think it’s a communication issue between the app and the Wyze server because all my other Wyze devices (cameras, floodlights, plugs, light switches, doorbell, etc.) are loading fine.
Any help would be awesome. Thanks!
Are you maybe on Android 17 beta?
Others have reported issues accessing the thermostat on Android 17 beta.
Wyze Thermostat Offline on Android Only - Home - Wyze Forum
Thanks for your reply but in on android 16.
I’m on Android 16 running WYZE App v3.19.0 (935) and thermostat is showing OK on my app.
Can you provide more details:
  • Posting pics of what you are seeing might help others understand and provide advice.
  • Is it showing as device offline in the app?
  • Can you display the Device Info screen? How many bars is Signal Strength?
  • When you say “powering off the thermostat” I assume you mean pull off wall and plug back in.
  • Is there any display on the thermostat?
Hi at the physical thermostat everything works. I power off at the breaker for few minutes on the app when I normally click the icon it goes right into the thermostat interface. But after the new app update this is show the loading icon and hangs till I hard exit out of app. It wont even let me delete existing thermostat or add new. I out in a ticket but I thinks its hanging between app and server before communicating to my thermostat. Basically I cant remote control it through the app as I have done for years since it was first released. Its frustrating!!!
