I would like to hear what solution people use to stream and record wyze cams. Thanks
Would you please be a bit more specific…what are you trying to accomplish? There are many different answers to the broad question you posted.
I stream to the Wyze app, and continuously record to the optional internal SD card (a capability available on all “wire-powered” cameras).
Welcome to the Wyze User Community Forum @john3738!
I use the Wyze App, TinyCam Pro, and Alexa on FireStick TV to live stream my cams.
All my cams record continuous to resident 256GB HE microSD cards. Any captures I need are recorded from the live stream or microSD Playback. If I need raw MP4 files, I can read the microSD on my OTR Card Reader. I also download event videos from the cloud Events tab. TinyCam Pro has a DVR feature, but I don’t use it.
I would guess that the solutions can be ranked in the following order:
- Stream with Wyze App and record to MicroSD card &/or Cam Plus
- Streaming through Alexa or Google Home integrations, but still stored on an SDcard or Wyze’s cam plus cloud
- Stream with TinyCam/Pro and use it to record to a local device or harddrive (whether from the app itself or to convert the stream to RTSP and save it elsewhere).
- Get Docker Wyze Bridge, and use it to get a different video stream format which can then run through any other video application on a server or computer.
- Wyze RTSP firmware - then capture the video stream to a local computer
- Wyze Hacks loaded on an SD card which allows converting the video stream to RTSP and using a local computer to capture and save the video stream.
- Install Dafang firmware onto Wyze Cam V2’s so everything can be 100% local on the V2 model cams, capture the stream and store it locally. No Cloud dependency involved.
I’d say the above options capture 99% of people’s streaming and recording.
Does the Dafang Firmware still use RTSP ? That would work nicely for what I use my cameras for.
Dafang provides RTSP connectivity but it is a standalone firmware and completely eliminates using the Wyze App for anything. The wz_mini_hacks provides RTSP and a few other streaming protocols but does not replace the Wyze firmware so it continues to work with the app.
