Sell Wyze replacement power cables
I wish you would sell the replacement cords for the cameras on your website. We are needing two and it would be nice not to have to order a third party one off amazon.
Not what you’re asking for, but just so you’re aware, the Wyze Cam Mounting Kit comes with a 5’ USB extension cable and the Pan Cam Mounting Kit comes with a 15’ USB cable.
Thank you! We are aware, we have about 8 wyze cameras, however, one of our kittens got ahold of the cord and we need to replace a few.
You need to replace a few cords or kittens :slight_smile:
Post over in Ask the Community, there have been several posts about USB cords. @Loki linked me to some great short cords
https://www.amazon.com/gp/product/B01B4SHM52/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
when I needed some to hook cameras together to share USB,
LOl, Never replace kittens. :slight_smile:
Longer power cord options for V3 & OG Cams
Hello! Is there any option for a longer power cords for the Wyze V3 or the OG? 6ft just is not enough in certain cases and I have yet to find an alternative for this other tha nunning super long extension cords which is just ugly! Pleas make 10ft, 15ft & 25ft cords and the option to stack the cords. So if I need 30ft, obviously I’d buy 2 of the 15’s, etc.
Thank you!
We have some of the cables listed here and hope to have more.
A Replacement Parts Wishlist
  1. Replacement cables for V4 cams . My Pan Cam V4 cam with what I guess is a Pan Cam v3 cable (mini USB) instead of USB C Yeah, that doesn’t work.
  2. Replacement USB connection covers (those little white rubber ones).
Nothing earth shattering, but useful
  1. I’d contact Support if you haven’t already. Cam Pan v3’s cable has an L-shaped Micro-B USB connector because of the way the female Micro-B port is integrated into that Cam’s base.
  2. FWIW, this has been requested in a related Wishlist topic, but that topic is also marked as Wishlist > Wishes Granted. You might also want to take a look at Where can I get only the rubber protective sheath that goes between the connection?.
If you ever need longer Micro-B cables for Wyze Cams that use that kind of connector, I linked to some third-party cables in a couple of posts in USB Cam Cable Repair Kits that I like.
  1. I bought and received a Pan Cam v4 that has a USB C connection on the camera but the cable in the box was a Pan Cam v3 micro USB L connector. I can’t use that cable with a Pan Cam v4. And there’s no source for OEM Wyze Pan Cam v4 cables ( which would also be Cam v4 cables).
  2. Those are all great suggestions. I’ve used various tapes and they don’t survive outside but whatever.
I understood this from reading your initial post, which is why I suggested contacting Support to let them know of the error and possibly have them send a replacement.
If I understand you, then I don’t think that’s correct, as (non-Pan) Cam v4 uses a Micro-B connector on its pigtail. A number of users were disappointed by this when Cam v4 launched, but I believe that Wyze didn’t begin introducing Cams that use a USB-C connector until later.
I haven’t tried the 3D-printed solution mentioned in one of the topics I linked. While I think it’s an interesting idea, I’d probably want the silicone sleeves for their elasticity and think they’d be more snug. I’ve read about other users applying things like dielectric grease as a water barrier, and I’ve wondered about using heat shrink tubing over the connectors for some applications, but I haven’t mounted any of these for long-term outdoor use, so I haven’t tried any of those ideas.
The Pan Cam v4 uses USB C. I’m looking at mine and it’s definitely USB C. I used a USB C cable to set it up. I have 2 (and a Duo Pan Cam). They’re USB C.
Tom’s Guide review
Video: 3,840 x 2,160
Field of view: 105.4 degrees
Night vision: Infrared, color with spotlight
Wireless: Wi-Fi 6
Weather resistance: IP65
Power: Wired, USB-C, 110-240V (AC) input, 5V/2A output
Shrink wrap tubing doesn’t appeal to me as it’s fairly permanent. I’ve replaced / upgraded multiple cameras over the years (mine are all outdoor) and it’s nice when you can leave power cords & mounts in place and just replace.
This is what I’m saying.
  • Cam Pan v4 uses a USB-C connector.
  • Cam v4 uses a Micro-B connector.
  • Cam Pan v3 uses an L-shaped Micro-B connector.
Because Cam Pan v4 uses USB-C and you received a cable with Micro-B, you should contact Support to inform them of the mistake and see about a replacement.
