Is there a way to be able to view my cameras on my Samsung tv? Do you have a compatible app to show me my camera feeds on my tv?
Hi @rosenysha, and welcome to the community. There are several different Smart TV OS’ out there. If you know which one your TV uses, try searching the #wishlist to see if a topic already exists for it. I do know there are already at least two topics already; one for Roku, and one for Android TV. If you can provide the specific OS your Smart TV uses, and there is no #wishlist topic for it already, then we could convert move your question to #wishlist. ![]()
I have a samsung smart tv. Do you know if there is something for Samsung tvs?
There definitely isn’t anything yet. The only TV platforms it works with so far are Google/Chromecast and FireTV, although I can tell you that the Google implementation is pretty spotty at this point. I’ve heard good things about the FireTV integration.
If you were to buy a FireTV stick, you could use that with your existing TV. I suspect Amazon will have Black Friday specials on them.
I have a firetv stick, do you know how do I get it to work on the firetv stick?
If you have your camera connected to Alexa and you have the Wyze skill enabled, I think you just ask Alexa to show the camera on your FireTV and it should pop up. That’s how it works with Google, although as I said, the implementation is spotty. (Video takes forever to load and disconnects prematurely.) Supposedly on FireTV it’s much smoother.
If the TV is not on when you ask Alexa to show a camera, nothing will happen unless HDMI-CEC is enabled. If it is enabled, the TV will turn on when the camera feed starts.
If nothing else works, you can get a cheap Android box with an HDMI port. Just make sure it has Google Play installed. Then you can install the Wyze app.
MOD NOTE: This topic has been retitled and moved to the #wishlist.
I use fire TV on my Samsung Smart TV to view my wyze cams , also works with fire stick.
https://smile.amazon.com/Fire-TV-Stick-with-Alexa-Voice-Remote/dp/B0791TX5P5/ref=gbps_img_m-6_c7e8_5be800c6?smid=ATVPDKIKX0DER&pf_rd_p=f5da058f-7214-4e12-924f-ec492877c7e8&pf_rd_s=merchandised-search-6&pf_rd_t=101&pf_rd_i=14611812011&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=RTMBDEJX87ZQ1XT8D7JX
We would like this feature, please. It would make our lives safer including our stress levels would be lower. Help us be healthier get Wyze to work on Samsung Smart TVs.
