What’s the difference between these routers other than colour?
Do Wyze routers get frequent firmware updates?
Can you add VPN’s to the router?
Wifi 6 vs Wifi 6e
no frequent firmware updates.
No VPN.
It’s a pretty basic Mesh WiFi system. I have the 6E. It works well. Solved all my weird Wyze Camera issues. I live in a 1600 sq ft house. I have 2 nodes. Main internet is centered in the house (that helps a lot). The other con is that they get REAL hot. I bought a little USB PC fan that I plug into the router to cool it. Helps a ton.
I’ve had them since launch. Great Signal and speed. Just no frills, no updates, and gets hot.
I thought maybe they’d have something like the “Wyze Cam Comparison Chart” but for the routers. Unfortunately, this doesn’t seem to be the case; however, I typed “mesh router comparison” into the search box on the Help Center site, and it returned this:
Wyze Wi-Fi 6 Mesh Router vs. Wyze Wi-Fi 6E Mesh Router Pro
- Internet Speed: Up to 1 Gbps
- Coverage: 1500 square feet per router
- Device Support: 50+ devices
- Technology: Wi-Fi 6
- Features:
- Simple app setup
- Parental controls
- Wired backhaul
- Two Ethernet ports
- Optimized antenna and stronger power amplifier
- Complete network control in the Wyze app
- Guest network management
- Price: $99.99 for 1 Pack, $199.98 for 2 Pack
- Internet Speed: Up to 2.5 Gbps
- Coverage: 2000 square feet per router
- Device Support: 75+ devices
- Technology: Wi-Fi 6E (includes access to the new 6 GHz band)
- Features:
- Simple setup
- Parental controls
- Wired backhaul
- Top-of-the-line components
- Class-leading performance
- Price: $173.99 for 1 Pack
Summary
- Speed & Coverage: The Wyze Wi-Fi 6E Mesh Router Pro offers higher speeds and greater coverage.
- Device Support: The Pro model supports more devices.
- Technology: The Pro model includes the latest Wi-Fi 6E technology, providing access to the 6 GHz band.
- Price: The Pro model is more expensive but offers enhanced features and performance.
I realize that doesn’t answer all the questions, but I thought it was interesting that the chatbot provided that kind of summary, and it seemed worth sharing.
The big difference is getting a 6GHz band on 6e.
I just have wifi 6.
I recently bought a S24 that can work with 6 GHz. I wish I bought the 6e. But I only have one device that can work with the full capabilities of 6e.
