Robot Vacuum Map Memory
Is the robot vac supposed to remember the map of the house?
It does not remember boundaries I set from previous runs and I find my self having to let the vac go into a room then setting a boundary at each run. Defeats the purpose of scheduling if I have to be supervising the vac at each run.
I have the same issue. I hope a software update may fix this issue as it is very important for my home. I also hope they make virtual walls more user friendly
Hi @SIV & @lrpcoo.mk Welcome to the Community forum! :slightly_smiling_face:
There is a new app to address some Vacuum troubles:
  • Android 2.16.55 (January 16, 2021) and
  • iOS 2.16.46 (January 16, 2021)
And a new Vacuum F/W update 1.6.75 (December 17, 2020)
Hope this helps . . .
Thank you
You’re welcome @lrpcoo.mk! :slightly_smiling_face: Did those updates solve the trouble?
I have the latest app and Firmware and:
  • It mapped my house pretty well on the third try (and after the latest app and firmware) but only saved about 80% of what it found
  • I now have rooms designated (although it thinks a hallway is a room)
  • But worst of all, I spent a lot of time setting up virtual walls and it remembered zero of them
Waiting for the next update in hopes it resolves these issues…
Hi @Camper-11 and welcome to the community forum! :slightly_smiling_face:
Here you go , a new f/w update. . .
