Push notifications no longer working
Has anyone received an answer from Wyze on why no more push notifications?
It’s not happening to most people, and seems to be a rare iOS issue. People have reported success following these steps to get it working again:
If it already looks like that for you, toggle it off and then toggle it back on and that seems to fix it for most people who have been experiencing this. Not sure why iOS notifications are glitching this way for some people, but toggling it back on in the iOS system settings seems to fix it for those having this issue.
I fixed the issue after trying everything by uninstalling the Wyze app and reinstalling it. After that everything worked.
Did you have to re-add all of your cameras after doing that to include pushing the setup button?
Thanks, but I have an android
For those having lost their push notifications, I found that deleting the app on my Apple XR and re-installing the app seemed to get my push notifications to work again.
So far, it’s been a couple of weeks and they it’s still working.
I hope this helps for all those having the same issue with push notifications not working.
Figured out with the settings for the apple 13 pro, under the focus tab, Do not disturb tab, there is an option for allow notification from certain apps. I added the wyze to that list and now it works.
