Is anyone else having issues getting event playback to function?
I am not.
Glad to hear that it isn’t everyone and just me. Thankfully SD playback is loading so I can get my important bird videos from my feeder.
Cloud Event videos loading fine in Oregon. Are you in the Central part of the US?
Yup, Minnesota here. AKA US HQ of fraud.
Not seeing any issues.
Bay area, 2:42 pacific time.
I’m in middle Tennessee and all my cams went offline at the same time about 1.5 hours ago. It’s not a power issue though.
In looking at down detector I’m not seeing any issues with Wyze, However being that you did give your time zone! thank you thank you thank you it does look like Amazon Web Services had an issue earlier and it was focused around Denver. There’s a good chance if you’re experiencing issues more than likely that was what happened. Amazon Web Services had some sort of issue located in a central hub in Denver and they’re working on it, It looks like there’s a lot of reports that are going downward in number now so hopefully it’s gotten fixed but this thing doesn’t tell me what time zone it’s reading in if it’s mine or somewhere else, But this is showing around 9:00 AM and as of 6:00 PM it is roughly half of what it was.
Sorry to hear that and hopefully things start working properly for you again. My anomalies have ceased and things are back to working once again. In other words, the events that would not play properly earlier in the day are now playing without a problem when I click on them within my Android app v3.12.0 (773).
Here a couple of links i have bookmarked for when i need to check for any reported Wyze outages.
https://support.wyze.com/hc/en-us/articles/360015979872-Service-Status-Known-Issues
FWIW, that can also be shortened to https://go.wyze.com/servicestatus, which is what I have saved (along with some Downdetector and other links) in a Forum Custom Section.
I got both bookmarked now, thanks.
Yes, events haven’t been loading for a while but support is not helpful. The self - help (aren’t there humans in Wyze corporate available to help?) answers are not helpful. I already checked for the latest software update (it’s on auto-update anyway). I also turned off the router and waited a long time before restarting it. I also cleared the cache. What else is there to do?
Did you also power cycle the camera and modem?
I have an Arris BGW210-700 Wi-Fi Gateway modem router. It functions as both a modem and a router. It supports concurrent Wi-Fi with 802.11b. I unplugged it and left it off for a long time to “reboot” it. Nothing changed. How do I “reboot” the camera? Do I have to remove it from its bracket? It seems the camera is working because it captures live video but when I try to watch a recorded event, an error message indicates there is no connection to the cloud. Wouldn’t that be an app error? I don’t know.
Are you able to flip the circuit breaker that feeds power to your doorbell?
Edit: I don’t have a Wyze doorbell so I was thinking it connects to your house doorbell wiring. If it is battery powered flipping a circuit breaker won’t work.
There are some that use batteries but mine is a wired doorbell camera. Yes, I can flip the circuit breaker. I’ll give it a try. Thank you!
