Palm Deadbolt
Hi I had a Yale Nest Deadbolt and I decided to go with your Palm deadbolt Witch Love It works Great
The only thing that I don’t like is.
There is no Privacy Option let me explain on my Yale nest lock I had a button on the back of the lock and if I push it. It would put it in Privacy Mode Witch means if my kids have a code the code it won’t work until I turn it off I could also do it from the App
Now I know the hardware is not possible to add a button on the lock But it is posable to do a software up date and add a Privacy button. And since you have Palm reader and security code it would nice if you can choose between one or both to disable them or enable them Think You
[MOD EDIT]
PS buy the way I changed all my cams and doorbell to Wyze
Violation: Personal Information Removed
In the meantime, what I have done sometimes is just switch people’s access profile from “always” to “temporary” and it turns off their access temporarily. Then I can switch it back to always or recurring whenever I’m ready to restore access to them.
I can see how a single button to do every other profile so at once would be convenient though.
