I opened a ticket for this in June which up until now was not resolved. I came back on here to check for updates and saw this post. Tried it and it solved mine as well. Now, to update or not to update??
That is great news. I beta test FW as I like to see what is coming and provide feedback. I have yet to have an issue with the updates, but I do a camera at a time and makes sure I do it in the order it suggests for the WCO.
The steps were provided by @Muda888 . Gotta give credit where it should be. ![]()
I haven’t allowed the update. I don’t plan to until they say they’ve fixed this. There were others having issues with the firmware update that was supposed to take care of this and I haven’t seen any updates since.
I updated to 4.16.2.16 back in August when it came out w/o any issues. That is until I got hit by a double whammy of loosing power (my 5yr grandson unplugged it) and the AWS outage occurring during my problem solving.
Long story short: After hardwire connecting the base and force loading the firmware to 4.16.2.37 (using the links and comments provided above and below (Thank You)) I was able to get everything back and fully operational.
(note: You don’t need to remove everything from the SD card when loading the firmware update, but you do need to remove the update folder afterwards.)
I have been a multi-comment complainant on this board but just to let you know I do now have the camera and base station working consistently, but only if I have the base station connected by ethernet cable to the router - not using wifi. So far at least…
After 6 months of wi-fi failure, I finally had success with app version 2.27.34 (6). Some caveats: turn off cellular data and any VPNs, and when the base is set up under Ethernet, tap the gear icon, then Device Info, and make sure that a wi-fi network has been saved. And I’m still not sure whether it will connect with a tri-band auto selection (SmartConnect); if not, try a separate guest network (the problem with spaces in the name is supposed to have been fixed).
