This feature seems to have been removed, was wondering if anyone has found a workaround.
Basically i have a wyze wall switch that is set to Single Press > Smart Control, and i want to add a smart plug for that to control. The only option I see now is just other wyze wall switch.
This used to work, reached out to support and they dont know why its gone, and possibly to be fixed in future firmware/app updates.
I tried automatons but that doesnt work for me either, unless I’m doing it wrong.
The only workaround I can find is by doing the double or triple press. Thanks!
This bug is still present in the switches. It doesn’t always happen but mess with those settings too much and they will stop working. If you get hung up just blank out all the settings in Additional Controls to make them empty. Back out of the switch, refresh your app, then go back in and set everything up the way you want. Editing what you’ve setup is where the bug comes in. If you change them too much (edit, go out, come back, edit, etc), then the Double-Click/Triple/Long action stops working. So you have to go through the blanking procedure I mentioned.
Not great. But, they work when left alone. We click the **** out of mine in my house.
Apparently Wyze broke this a while back, so there’s been a Wishlist request to restore this feature since October of last year[1]:
As with any Wishlist topic, you can visit that one to click or tap the Vote button above the initial post and share your ideas and use cases in the comments to show your support for the product and feature request/suggestions that are important to you.
Ooh thank you! I tried searching but I didn’t see this. Yeah, at the time when i got the flood and plug, the plug was an option but the flood option was there so I just assumed it was never supported.
Support was pretty vague about the planned fix lol, so heres to hoping. Thanks for the link above!
