In last day or so some of my camera motion alerts are using a different sound (wyze sound 1) than my setting, Wyze sound 3.
I tried changing the sounds and saving it, and still some are notifying with incorrect tone.
Anyone else having this issue?
My issue has consistently been that none of the built-in Wyze app sounds work as the notification sound, going back through multiple production app versions, so as an Android user I’ve just configured a custom sound on my phone instead. ![]()
You didn’t mention what app version you’re using, but based on the timing I wonder if it’s related to the most recent hotfix. If I wanted to try getting my in-app notification sound to “stick”, then I’d probably try refreshing the local account settings/profile.
I’ll be interested to learn of other users’ experience, because the built-in sounds have been broken for me for so long.
This seemed to work. I am on whatever the most current version is (v3.2.1 (581))
Thank you!
You’re welcome. I’m glad that helped. Thanks for taking the time to report back!
