How do I make the push notification have a sound? I want to know when I’m receiving notifications without constantly having to check the screen of my phone.
This is decided by your OS. The answer partially depends on which OS (Android/IOS) and then which version of that OS you have. There are walkthroughs online for each kind. You just follow them for the Wyze app notifications and it will work.
For example, on Android 11, I find a Wyze notification, slightly slide it left or right, click on the gear icon, and select Default (sound) or Silent (no sound), or select the gear icon again and change some more individual settings.
