New Beta Update
So ever since I updated the battery cam pro to the beta update it records every motion event even though I have it set to only record when it detects a person anyone else having this issue?
Go to settings - event recording - temporarily switch it back to all events
Now go to customize detections & uncheck other motion. Now switch back to smart detection events again.
Your problem should be solved.
What specific firmware version are you on now, that your having an issue with?
It won’t let me uncheck other motion the box is greyed out only uncheck other motion notification
1.4.2.3615
Yeah, I just meant uncheck the notification for other motion before switching back to smart detections only (if you don’t do that it will keep notifying for motion detections and sometimes keep showing them in the events tab…)
Make sure to do everything else in that list though.
