I’ve been battling this for 5 days straight. Here is a LIST of ALL that I have done with not a single solution to fix this issue…
Netgear RAX120 with EAX20 Extender. All Equipment working flawlessly with amazing download and upload speeds on 1GB Fiber. Network is flawless at this point.
Added (2) pan v3 cameras to network, Updated both to latest firmware.
Outdoor Camera (Connected to extender on guest network for IoT Isolation) Fails often.
Main Camera (Connected to router on guest network) Works Perfectly.
Checked Wifi interference with neighbors. Selected new channels (Started at 1, then 3 , since they were least congested, Dropped 2.4ghz to 20MHZ. Enabled local network access on guest wifi / IoT Network)
Disabled 5ghz guest network on extender and router.
Speed test setup, success.
Reconnected outside Camera to guest extender separate network.
Worked for a day, Then No Dice.
Factory Reset Router and Extender, both are mesh network capable.
Factory Reset Camera.
Setup Individual guest networks on Router and Extender for my IoT devices.
Moved back to 2.4 on 40MHz.
Camera Fails at random times, will not reconnect to guest network on its own.
Power cycle camera works as temporary solution. Using smart plug to set restart schedule.
Blink camera’s within 1 ft of wyze camera for trouble shooting, gets crystal clear and low latency video anywhere.
Wyze Camera on Extended Network, fails.
Wyze Pan v3 close to main router on guest network works perfectly.
Purchased new router and Extender, Did all the above again on day 3. FAIL on Extender Camera.
Factory Reset both router and extender, Updated firmware manually to both.
Factory Reset Camera’s.
Reconnected all 50+ IoT devices after main and guest network setups.
Speed test 2" from camera location. Full speed, barely any jitter, 12ms latency.
Removed all IoT devces from extender network to isolate camera. Still disconnects.
Turned on Upload QoS, no help. Turned back off.
Start over with extender, Router Verified running above internet service speeds. All devices functioning except camera. Even on an extender BY ITSELF, It still craps out randomly.
Returned Wyze camera, purchased new one, added to network… SAME ISSUE!!! Disconnects…
Swapped power brick for bigger one, swapped power cord. Runs a little better with a bigger brick. Failed after a long period of time, maybe 12-14 hours. Best results yet. (Seems like they should be giving this device more power, its snappier. Could just be me out of hoping it works.
Wiped The Entire setup on day 5 and started over again. Still the same damn thing…
Manually set IP addresses for ALL IoT devices. Performance of network and IoT devices improved greatly! Outdoor Wyze Camera connected to extender network functioned for a day then crapped out again.
After 5 days and $400+ dollars in new equipment (Because I Love solving problems and don’t know how to give up on problems) I am STILL at square one.
Wyze FIX THESE CAMERA’S!!!
