More Camera intergrations!
We would really like to see more friendship between cameras and Wyze sense, if you choose to have notifications turned on, for lets say “detection setting” or “movement setting”, it would be nice to only have the camera send motion or detection or what ever, when alarm has been turned on to ““AWAY” or “HOME”” mode, but no need to have this notification sending us messages all day long, unless one chooses this mode, we should have a choice as to when the cameras notify us of something we ask for it to do !! monitoring should still be available if we want to see whats up, but a “choice” of notifying or not !! tnx!!
Welcome to the forums! It is a requested action for rules that when the hms mode changes, to have a rule action to do something via rules. Until then, you could create a shortcut rule, or scheduled rule to enable and disable either motion detection or notifications for your cameras when you want.
This info is of no help. the same problem exists, no way to disable notifications if cameras are on! except to turn off notifications. why cant we have a option of, only having a notification sent, when alarm sys is activated?
⁣Get BlueMail for Android ​
Because it isn’t currently supported by the application.
That was the whole purpose of the post! it should be!! tnx…
Perhaps you should submit this as a “Wish List” item then.
Just vote on the existing one…
It is a fairly commonly requested addition to hms and rules. Until it is implemented, we have to wait or do a workaround. I was providing a work around in the meantime. You can set your forum notification settings on the above-linked wish list to watching to get updates on future posts and potential updates from Wyze team members on it.
