Upcoming Test for the Security…
Wyze Home Monitoring customers,
We have scheduled a test for a Security Camera feature fix from 1-2 PM Pacific on Wednesday, 03/02/22. During the test, you may receive push notifications or Critical Alerts depending on your Security Camera configuration. Please note that Critical Alerts are an iOS device feature and Android users will not receive them.
Background
We believe that the best security system is the one that prevents bad things from happening instead of the one that only requests help when someone has already entered your home.
The Security Camera feature in Wyze Home Monitoring was meant to be an outer layer of protection to prevent intruders from entering your doors or windows. At the least, it would give you strong warnings before the situation escalated. That’s why we encourage you to add cameras facing outside your perimeter to your Security Camera list.
However, the Security Camera feature had some issues and didn’t work as expected. So we removed the product logic and only kept the Security Camera app interface over the past year.
After thorough investigation into our cloud software and firmware for multiple cameras, we have identified the root cause of the issue. We are gradually releasing the fix after development and internal testing. The last step of the fix is to test it in the environment our customers use instead of a private internal one.
Recommended Configurations for Security Cameras
You are able to set different notification parameters for your Security Cameras in the Wyze app by going to Home Monitoring Settings > Security Cameras > Threat Alert. Here’s our recommendation for setting up an effective Security Camera without it sending a frustrating number of alerts:
Imagine your system is in Home or Away mode. What are the events from your Security Cameras that you don’t want to alert you even if you are sleeping and your phone is in Do Not Disturb mode? Then, uncheck those event types from the Security Camera’s settings.
For example, you may have added three Security Cameras. One is facing the lane in your front yard that leads to your door, another is placed in the garage, and the last one is monitoring the back yard and its fence. Because there are squirrels and raccoons in your community, you don’t want to be woken up in the middle of the night because of the animals. In this case, you may want to uncheck “Motion Detection” for the front yard and back yard cameras. However, you probably want to be alerted if a person shows up in those two areas when your system is armed so you may select “Person Detection” for the two cameras. But for the camera in your garage, you may want to be alerted to any movement because it’s a closed space and you’re not expecting activity when the system is armed. Selecting “Motion Detection” would make sense for this camera though you may want to lower the motion detection sensitivity to reduce the odds of being alerted because of floating dust. When night vision is on, floating dust and cobwebs can trigger the motion detection.
But if you don’t want to be disturbed by any Threat Alerts, just select Off for Notifications under Threat Alerts.
What to Expect
During the test window of 1-2 PM Pacific on Wednesday, 03/02/22, we may enable and disable the feature logic multiple times. Once enabled, if your system is armed as Home or Away, the capabilities you selected for a Security Camera will trigger the action you chose in Home Monitoring Settings > Security Cameras > Threat Alert. The notifications could be Critical Alerts (default for iOS), push notifications (default for Android), or they could be turned off.
After the test, we will evaluate the results. If the fix meets our quality standards, we will officially release the fix for supported devices next Thursday, 03/10/22.
Please be assured that during the test, and after the fix has been released, triggering a Security Camera will NOT dispatch the police regardless of whether you’re using Test Mode or not.
Here are the Threat Alert triggers that will be tested and released:
- Wyze Cam v2: Motion detection and Person Detection
- Wyze Cam Pan v1: Motion detection, Person Detection, and CO/Smoke alarm sound detection
- Wyze Cam v3: Motion detection, Person Detection, and CO/Smoke alarm sound detection
- Wyze Cam Outdoor: None (work in progress)
- Wyze Doorbell v1: None (work in progress)
Thank you for your patience while we work on this issue. Please stay tuned for the fix for remaining triggers.
Wyze Home Monitoring Team
