On Tinycam after a few hours my Battery Cam Pros will start to have a 10 second delay and my V3 cams do not. I’ve tried emailing Alexey every day for 2 weeks with no reply. Does anyone know what might be causing this? Alternatively, I would accept other viewing methods as a solution. My goal is to view 6 cams on one screen on my smart TV. Does anyone have any experience with the IP cam viewer app? I’m new to this but I think I could use a WiFi NVR with my cams then HDMI to the smart tv from the NVR. Do I need to flash the Wyze cams for the RSTP firmware for that? If I go HDMI directly from NVR to smart TV will I be able to control some sort of interface with my TV remote and select how many cams I am viewing at once? I have seen you can do that but not sure if I need to have it go through a laptop or something to control it. Or maybe I could control the view remotely through a web server and that would display on my smart TV? Does anyone know any WiFi NVRs that would allow me to have a 6 cam view? Why doesn’t Wyze app have a 6+ cam view on their app and only 4? You can view multiple 6+ cams at once on my.wyze.com/live but I don’t want to pay a monthly fee. Any help would be greatly appreciated. Thank you.
I would expect that the 4 limit on the app is because it was designed around using on a phone, and if you try to view more than four cameras, the image gets really small. my.wyze.com/live was designed around watching on a PC which normally has a far larger screen size.
Just my speculation.
You wouldn’t want to use the app anyway. Any disruption and they don’t keep trying so they go down. The app isn’t good for continually streaming.
Also there’s far too many points to cover. Like these are internet based cams so they’re hitting your internet quite a lot at 6. Especially if you add certain features then it only increases.
The 10 second delay for instance should normally drop to say ~1 second or so on lowest quality stream. (This issue will do better and then do worse but lowest quality does better most of the time.)
You also really don’t want to use the outdated rtsp firmware that isn’t going to have security fixes and may have problems with the app as well. Its not a good way to go.
This sounds very similar to something raym64 and I were discussing in this thread:
Not necessarily. In fact, if you run Tiny Cam Pro in Server mode on a local device, it will give you an RTSP URL you can plug in without different firmware. There are a few other options that will convert Wyze video to RTSP without changing the firmware (Scrypted, Docker Wyze Bridge, etc). In fact, Tiny Cam Pro, Docker Wyze Bridge, and Scypted all by themselves allow multiple cameras viewed at once, but getting another program can allow more customization.
Yeah that makes sense but still why not? Some people use the app with larger tablets and would like that. Or people like me who would rather use their app than need to use someone else’s app. I would think that would be a relatively easy thing to do?
I’ve been using Tinycam to stream 6 cams for a few months now theres a few crashes here and there but probably is working 80% of the time which has been acceptable for me. Do you have any solutions to how I can view 6 wyze cams at once on my smart TV other than Tinycam or the wyze web browser?
Sorry I’m new to this so I’m a bit unsure what you’re saying I should do. What am I plugging the RTSP URL in to and why am I converting Wyze video to RTSP? I am currently using Tinycam to view 6 cameras at once but it appears the app does not work properly with the Battery Cam Pro which I just bought 4 of and am trying to use.
edit: I think you mean I can plug the RTSP URL into an NVR. If so that would be great so I don’t lose out on security updates and person detection and such. But I still have a few unknowns about NVR’s as noted in my original post.
Correct, Usually the NVR has some sort of software that will ask for your RTSP link or something. You would paste it into there.
I think most of them allow this in one way or another. I don’t feel qualified to recommend one in particular. I mostly intend to use Scrypted or Frigate as soon as I finish setting up docker and portainer on my miniPC. But for viewing 6 cameras at t time I have done this with just Docker Wyze Bridge. This is an old screenshot of it I took back in January:
Great thank you so much I’ve been trying for days to get help here with this. I think I might be able to buy a cheap laptop (hopefully having enough processing power?) and set up Wyze docker bridge on that then HDMI that to the smart TV. I’m not a fan of leaving the laptop on 24/7 but it’s an option. I think an NVR is still my best bet so I need to look into that a bit more. I don’t know if I can interact with the NVR interface if it’s plugged into my smart TV with the TVs remote or I have to do it through a web browser or route it through a laptop or something. But at least I know now I don’t have to lose the more modern firmware which is great to hear. if all else fails I can just try to return my Battery Cam Pros and use the Wyze V3 cams because the V3s have no issues on Tinycam.
It doesn’t take a lot of processing power. I was running it on my Synology NAS for a while along with several other things until I decided I wanted to move all my dockers off of my NAS so I could keep it’s resources reserved just for storage and run other stuff on a mini-PC. So what I am saying is that most computers should have sufficient resources to run it. It wasn’t very intensive.
Just remember, you usually have to do that within the first 30 days if you are going directly through Wyze for the return. Some of the other retailers that sell Wyze stuff might have different return policies though.
Oh wait, I just remembered, Docker Wyze Bridge doesn’t support Battery Cam Pros right now.
There is a new project working on resolving that, but right now Docker Wyze Bridge only works with the cameras that support TUTK (the authentication service Wyze uses on most, but not all cameras). These are the models that Docker Wyze Bridge won’t work on right now:
So it sounds like that actually won’t be a solution for you.
Is tinycam still the only other alternative?
No, but it is the EASIEST free method.
Since my previous comment, there is now another RTSP converter project that supports the Wyze Gwell-Based Cameras that use the Iotvideo SDK from Tencent Cloud. So between that and Docker Wyze Bridge, most Cameras can now run RTSP and from that there are tons of options to do your own customizations.
There are several other projects to convert Wyze cams to RTSP:
Common 3rd Party Solutions to get RTSP on Wyze Cameras:
- Docker Wyze Bridge
- GitHub - mrlt8/docker-wyze-bridge: WebRTC/RTSP/RTMP/LL-HLS bridge for Wyze cams in a docker container
- = For Wyze cameras that use the TUTK SDK from ThroughTek
- Cryze:
- GitHub - carTloyal123/cryze: Cryze is a Wyze Gwell Camera Bridge that allows you to stream your Gwell based Wyze cams to locations of your choosing.
- = For Wyze Gwell-Based Cameras that use the Iotvideo SDK from Tencent Cloud
- Tiny Cam Pro in Server Mode:
- https://play.google.com/store/apps/details?id=com.alexvas.dvr.pro&hl=en_US&gl=US
- This App has historically supported ALL Wyze cams, but can only be used on Android. Many people use either an old Android phone or an Android Emulator on a computer to run it constantly. The creator/Founder became a Wyze Employee in 2020.
- Scrypted:
- GitHub - koush/scrypted: Scrypted is a high performance home video integration and automation platform
- Scrypted now natively supports Wyze to get RTSP, though most people in their Discord server recommend just using Docker Wyze Bridge instead to get the cameras into Scrypted, it is included here for convenience.
- Wyze Hacks:
- GitHub - HclX/WyzeHacks: Hacks I discovered allowing Wyze camera owners to do customizations
- Note that this project may lose some functionality with some of the newer firmware, and while you may be able to revert back to older firmware, you may put your security at risk by doing so.
- wz_mini_hacks:
- GitHub - gtxaspec/wz_mini_hacks: wz camera mods... make your camera better.
- Xiaomi-Dafang-Hacks Firmware
- GitHub - EliasKotlyar/Xiaomi-Dafang-Hacks
- This is a local-only RTSP firmware that works with the Wyze V2 and Wyze Pan V1. Note that your camera will no longer work with the Wyze app/services.
- Thingino project:
- https://thingino.com/
- Open-source Firmware for Ingenic SoC IP Cameras, which includes Wyze Cam Pan 1, Wyze Cam 2, Wyze Cam Pan 2, Wyze Cam 3, Wyze Video Doorbell 1, Wyze Cam Pan 3 (conditionally supported and has Secure Boot which could render your camera unusable). Make sure you download the firmware that matches the camera model, SoC, image sensor, Wi-Fi module, and flash chip size.
- You can follow this video and script to identify which firmware you’re supposed to get for your particular camera (which hardware revision your camera is): https://www.youtube.com/watch?v=SX637mrp0R0
- atomcam tools:
- GitHub - mnakada/atomcam_tools: Hack tool for atomcam and wyzecam.
- Hack tool for atomcam and wyzecam
For those who want all of the original and now deprecated Wyze RTSP firmware directly from Wyze, you can still get them here:
[Insecure] RTSP FIRMWARE [missing critical updates] Directly from Wyze:
- V2 - 4.28.4.41: https://download.wyzecam.com/firmware/rtsp/demo_V2_RTSP_4.28.4.41.zip
- V2 - 4.28.4.49: https://download.wyzecam.com/firmware/rtsp/demo_v2_rtsp_4.28.4.49.bin.zip
- V2 - 4.28.4.50: https://download.wyzecam.com/firmware/rtsp/demo_4.28.4.50.zip
- V2 - 4.28.4.51: https://download.wyzecam.com/firmware/rtsp/demo_4.28.4.51.bin
- Pan - 4.29.4.41: https://download.wyzecam.com/firmware/rtsp/demo_Pan_rtsp_4.29.4.41.zip
- Pan - 4.29.4.49: https://download.wyzecam.com/firmware/rtsp/demo_Pan_rtsp_4.29.4.49.bin.zip
- Pan - 4.29.4.50: https://download.wyzecam.com/firmware/rtsp/demo_4.29.4.50.zip
- Pan - 4.29.4.51: https://download.wyzecam.com/firmware/rtsp/demo_4.29.4.51.bin
- V3: https://download.wyzecam.com/firmware/rtsp/demo_v3_RTSP_4.61.0.1.zip
- RTSP installation/setup instructions: https://wyzelabs.zendesk.com/hc/en-us/articles/360026245231-Wyze-Cam-RTSP
If needed, here they are forever saved on the internet through the wayback machine:
- V2 - 4.28.4.49: https://web.archive.org/web/20220728034633/https://download.wyzecam.com/firmware/rtsp/demo_v2_rtsp_4.28.4.49.bin.zip
- V2 - 4.28.4.50: Wayback Machine
- V2 - 4.28.4.51: Wayback Machine
- Pan - 4.29.4.49: Wayback Machine
- Pan - 4.29.4.50: Wayback Machine
- Pan - 4.29.4.51: Wayback Machine
- V3: https://web.archive.org/web/20220728035300/https://download.wyzecam.com/firmware/rtsp/demo_v3_RTSP_4.61.0.1.zip
- RTSP installation/setup instructions: Wyze Cam RTSP – Wyze
Where could I find a good list of NON-free options?
I’d like to be able to set up some multi-view screens.
Step 1) Decide how you’re going to get all your cameras to use RTSP (or similar local stream). See my original list in the previous post for all known options.
Step 2) Decide on a Multi-screen Viewer.
Popular paid options include:
- BlueIris (Paid - Approx. $100/year)
- A comprehensive surveillance system that supports multiple camera views and offers advanced features like AI-based person detection.
- iSpy (Free/Paid - $40)
- A surveillance software that supports multiple camera views and offers features like motion detection and recording.
- Wirecast (Paid - Approx. $600)
- A professional live streaming software that supports multiple camera views and offers advanced production features.
Popular Free options include:
- VLC Media Player (Free)
- A versatile, open-source media player that supports RTSP streams and multi-screen view.
- AnyCam (Free)
- A user-friendly IP camera viewer that supports multiple camera views, including video wall mode.
- EasyPlayer-RTSP (Free)
- An open-source RTSP stream player that supports multi-window and multi-instance playback.
- IP-Freely (Free)
- An open-source IP camera stream viewer with multi-threading and cross-platform compatibility.
- PMPlayer (Free)
- A professional media player that supports RTSP camera viewing.
- FFmpeg (Free)
- A powerful multimedia framework that supports RTSP streams and multi-screen view.
Some people love to use Bluestacks for free too, but it will limit you to 4 cameras at a time just like the app on the phone.
