Is Wyze having an outage?
All of my AC powered cameras went down this morning, and are still down. Rebooting didn’t help.
My two outdoor cameras (that connect to a base station) still work.
No, there were no changes to the router or wifi recently. No power outages either.
It could be a number of things of course. In this case, where it is basically only happening to you and not being reported by other people (I checked down detector too), My primary guess would be that there is some kind of memory leak conflict. This often happens with routers and modems and other devices even if nothing changed with the network. My suggestion would be to restart the modem and the router, and then restart some of the cameras. This will force everything to clear any potential memory leak and also Force every device to get a fresh brand new handshake connection. Do this even if you are absolutely certain that nothing changed with your router or modem. Memory leaks are invisible and often unpredictable.
