Sounds great. Can I trade in my recently new Outdoor Cam which doesnt work very well?
My bad!
2/3 of the âIâll get back to youâ responses were directed at me
and I even actually already knew the answer to some of them, I was just trying to get an official public response I could quote and refer people to for future use as a Maven in helping people here in the forumsâŚpeople naturally prefer employee citations over just trusting a volunteer because I said so
I do appreciate the effort you and he are making to get good thoughtful responses on some of them even though the event is officially over already! Major respect on the effort on this AMA.
I realized I forgot to ask my standard âis this new device Linux Based or a Free RTOS based OSâ as Iâve been doing with every new launch, and I forgot, but in a previous AMA they said they were going to use RTOS on battery cams and things that need to use as little power as possible, so itâs safe to say that this one is RTOS, especially since it doesnât already have all the special features that the Linux Cams already have.
I think my Wyze solar panel is micro USB. Is there an adapter I should be using to plug into the USB C?
Did you purchase the solar panel with the Battery Cam Pro or was this a solar panel you already had?
Hi Jason! I just attempted a fresh setup/pair of the camera and submitted a log as requested. Log ID 1132676.
Hope it helps!
Thank you
Ability to automatically stream Battery Cam Pro (BCP) view (Power Saving Mode off) is non-functional. User must tap the Play icon to initiate a live stream regardless of Power Saving Mode setting. Issue applies to single BCP view and BCP in a cam group. Issue exists in both Wyze app versions 2.44.1.326 (Android) and 2.44.1.1 (iOS).
Log ID: 1132694 (submitted via Wyze app for Android version 2.44.1.326)
No, I purchased earlier this year from Wyze. This was for my Wyze Outdoor Cam V2. Pretty sure it has a micro-USB end.
Enable Battery Cam Pro auto streaming in groups
The new battery Cam pro does not start auto streaming when opening a group, even when power saving mode is off.
Please add a option, or enable by default, auto stream if power saving mode is off.
Additionally, the startup time is quite slow.
[Mod Note]: Your request was merged to this topic since it involves an issue and not a request for a new product or service enhancement by Wyze.
The new ones are supposed to come with an adapter cable for the panel. It sounds like you just need the adapter cable since the older panel is the same specs.
@seapup, is your Battery Cam Pro in a group, if it is could you remove it from the group and see if it then auto streams?
It doesnât auto-stream from the home page when not in a group, but I donât think any cam is supposed to. When not in a group, tapping the BCP thumbnail does successfully bring up a live stream.
We can repro that in a group it will not auto stream, but when we enter live view from the home page when cam is not in a group the stream is auto starting.
Same. âWhen not in a group, tapping the BCP thumbnail does successfully bring up a live stream.â ![]()
No luck pairing. Android 13. I canât believe this wasnât tested or found before they shipped out. Glad it I received so fast, props for that I guess.
Night vision turned off , camera light off, color night vision is awful compared to other Starlight sensor cameras Iâve tested in exact same spot hard to make out any color at all
