How to view backed up camera footage?
Hi,
I backed up some continuous recording from the cam v3. Now how to do I view them? They just 1min recordings.
Do I have to copy them back into the sd in order review them on the camera app?
Thanks,
David
If you want to view them in the camera app, then yes, they need to be on the SD card and in the camera as they were before.
If you want to view them on your computer or on your phone in a different app, load them into any video player and you can watch them. Some programs will let you load a bunch at a time and will automatically splice them all to run together as if they were one file.
There is a walkthrough in the following post about how to join all the videos (or as many as you want) into one video, so they aren’t just 1 minute each:
Got it. That’s very helpful! Thanks.
