My garage door controller was working perfectly before the firmware update on 1/17/2024. After the update… it wont connect. At all! I tried to do a reset (holding down the reset button on the cam for 10seconds) added it back on, which it connected fine through the setup process. After it was done, it wouldnt connect and the status light rapidly flashes blue. Ugh… anyone else having this problem?
There’s a service advisory:
Your stuff should come back. It’s not related to the firmware update other than it caused the camera to reboot and any camera that reboots isn’t authenticating right now.
