Failed to upload event!
Hi @mgreyeyes and welcome to the Community!
If you are looking for help on your Wyze Cam v2 it would be good to start a new thread.
This thread is from April 25 2020 and is associated with Beta software.
To start a new thread for discusion go to the top right of the page,
and click on + New Topic
When you start your new topic please highlight the “same problem” you are referring to and paste it into your description.
Hope this helps. :slightly_smiling_face:
Same error - Failed to upload …
Some videos can be played but most no.
Ticket: 56618
Out of curiosity, do you use a microSD card or no?
I frequently get these errors often but don’t use a microSD card. Of course, the first inclination that people point to is “your WiFi stability.” But I don’t have WiFi issues with any other video platform including iVideon (IP camera recording service) which I run simultaneously with Wyze (due to Wyze’s unreliability).
No, not using MicroSD.
Should not have WiFi problems as well.
Having this camera for almost 2 years. First time I noticed this problem a week ago.
Have you recently upgraded your camera’s firmware?
I only started noticing these issues around the same time that I updated to whatever firmware was available over the summer. The issue happens to me across ALL of my cameras. There are plenty of users in this thread who mentioned observing the same issue.
I have not checked the cameras for quite some time before because I was mostly home (working from home).
Recently I reset my modem (forgot the password) so had to reconnect a bunch of stuff, including my camera. It asked for an update which I did.
A couple days later when I was out, I decided to check my Events (got a notification) but was not able to due to this error.
There you go. These problems only cropped up when the spring/summer firmware updates were released.
I am also having this problem and it aggravates me because these videos are going away and I need to download them before they do yeah I am getting the same error this is so aggravating please fix this crap
