jjrowan
February 10, 2024, 4:02pm
Just installed the Cam Pan 3 unit. Didn’t want yet another subscription so opted for 32GB microSD chip to be able to view motion detected events. I formatted the chip using the app and app shows it’s there. I receive event notifications but when I click on the SD chip icon it always fails to load any motion events. What am I doing wrong?
Seapup
February 10, 2024, 4:08pm
The ability to view a Cam Pan v3 event from the SD card has a bug or two:
Hello everyone,
We had a callout for new issues last week but did not have a lot of responses by Monday. So we extended the deadline and I escalated some issues later in the week. We do not have updates on those issues yet, but we could use some logs if you are experiencing the issue. We do have some updates on the issues we have been following though so here’s our Fix-It Friday follow-up:
Reddit - Wyze Cam Pan v3 microSD playback button is grayed out on Event Viewer
Please send in a log if you are experiencing this. Here is how:
In the Wyze app, go to Account > Wyze Support > Submit a Log. Select your device from the dropdown menu. Then fill in the description box with the date, time, and time zone of the most recent time you noticed this issue and a description of what’s happening. Make sure the Send Logs option is selected and then submit your log. When you have the log number, please post it and tag me so I can get it to the right folks.
1380952 is the log number
1508156 will not load from.local storage
1600289 failed to load from local storage
1736432 failed to load from local storage
On brand new wyze camera. Error began after camera was active for only a week. Disappointed.
dave27
January 26, 2025, 5:40pm
The two things that commonly cause that are a poor wifi signal or an issue with the micro SD card.
Hunter
March 23, 2025, 6:33am
My wifi is strong and I’ve checked it with 3 different sd cards
dave27
March 23, 2025, 6:44am
11
Replying on multiple threads is not going to help you find a resolution. Stick with the one you created.
