Event tick marks on timeline
Would it be possible to add motion event tick marks on the SD card timeline? This would make it much easier to scroll to items of interest rather than scrolling endlessly. Thank you
Good idea. We are actually looking into this.
The SD card timeline normally has icons for events, however there is a known bug with OG cams not showing those in the last several months after an app update. @WyzeMatt are you aware of that and is it being worked? It affects all OG cams.
Unaware of the issue. Can you post screenshots and which app update caused the issue.
Appears it may have been 3.1.5 in October. Impacts all OG cams seemingly regardless of firmware. If I view them in the old 2.5 app, icons are still there. In the first thread, at first I wasn’t having the issue but after updating the app I got it also.
@dave27 provided exactly the right links. See this specific post for some side-by-side screenshots:
I believe this feature got hosed in the v3.0.5.558 to v3.1.5.569 app update.
Another odd behavior with the OGs that started way before, even in the 2.5 app. Pressing the forward and back buttons (overlaid on the video) used to jump between events when the SD card had continuous recording. Now they just jump 1 minute forward and back, regardless of events. Works fine with event only, it jumps between events as expected, but not on continuous.
