No timeline in Wyze OG playback from SD card?
I just got an OG and set it up yesterday with an SD card like all my other Wyze cam, When I went to look at it this morning, I notice there is no view playback “button”. There is an SD card “button” and once I press that I do have access to the recording. However, unlike other wyze cam with view playback, there is no timeline scrolling available, you can only do 30s or 2 min jump. That makes it beyond painful if I want to look at footage from say 4 hrs ago. Am I missing something?
The OG has the updated UI compared to cameras that came before it. The OG “timeline” is vertical scrolling now, not horizontal like the older interface. After pressing “SD card”, the timeline should show and scroll up and down to browse, and pinch in and pinch out to zoom in on the time or zoom out the time codes
Ahhh Thankyou! Found it.
Before you ask, there is a known bug right now with the app where the OGs don’t show the event icons on the timeline. If you have event only recording, not a big deal since you can see where the recordings are, but for continuous recording it can be a bit confusing. You can still use the event screen to jump to the right part on the timeline/sd card though.
