I have not seen 3001 since the last firmware up date. Not sure that it’s cured. I don’t check events as much as I did at one time. Tired of the app begging me to get Cam Plus every time I touch it. Or to buy something else Wyze is peddling.
Could be they finally took care of the problem. If that’s the case, no pat on the back for Wyze. It took TWO YEARS. Or maybe others feel the same way I do and were tired of wasting time talking about 3001 and seeing nothing happen.
Yes I still have the issue. I’m more concerned about half the cameras that I own being useless than Wyze exposing a limited amount of cameras to someone else for a brief period of time. Has anyone told Wirecutter that the actual cameras don’t work?
For anyone still having problems, will you post which camera model it is and what the firmware version is (go to settings and then Device Info)
Also, just in case it matters, please list your phone model and app version.
2 Pan Cams, FW 4.10.9.1851
2 V2s, FW 4.9.9.1851
The one V2 I have on the “Cam Plus” has the same FW and is NOT having the error.
I have 2 V3’s that do not seem to be infected.
Android phone is a Google Pixel 4a and has App V2.45.0 (342)
As there is no explanation from Wyze about the cause or correction, I assume with the new firmware it will mean that newly recorded events shouldn’t have the error but events recorded before the firmware update will still display the error in the app?
I have also been experiencing this issue for some time on my Wyze Cam Pan using Android.
Firmware - 4.10.9.1851
I did a manual FW update for the cam-pans and that seems to have helped.
The FW update was released today for my V2s so we’ll see how that goes.
Here’s a list of the most current FW versions.
[https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware]
Thanks for the followup @Fisherguy . If you find the error recurring after the updated firmware, please check back!
@marketwiz99 it looks like you still have the old firmware. The fix for this error on the Pan Cam will be with firmware 4.10.9.2351 which says gradual release, but Wyze indicated it should be available to everyone now. Fisherguy indicates that they didn’t have it show up for the Pan cams yet either. I will let someone at Wyze know that not everyone is seeing the update yet like they indicated in their Fix it Friday report. Maybe they only released the V2 fix to everyone and the Pan cam fix hasn’t made it to that point yet. They were released around the same time, so I expected they should both be on the same release schedule to everyone. I will ask and see what we can find out.
Mine all seem to be cured, finally.
