Error Code 05
Just recently started getting error code 05. Saw a few topics about this but didn’t see how the issue was resolved. Any help would be greatly appreciated.
When this happens to me, I simply do the Live Stream and the select Restart in the settings area. Otherwise, I remove power from the Problem Camera, wait for about 15 seconds, the apply power back and let it boot up.
Restart didn’t work. I will try unplugging the camera when I get home.
Update for those who have this same issue. Unplugging and powering back up fixed the error. Thanks @spamoni
My pleasure. Glad it worked for you.
Just to chime in on this older post.
  1. My Wyze app v 2.31.0.145 does not have a reset option in the settings. I only have v1 cams. No there is nothing below delete like I saw in several videos.
  2. I’m not sure how unplugging would help, my Wyze Cam v1 is battery powered, pulling the power cord should have no effect.
  3. I did power cycle, but I still can’t see the events from the past few days. I can see older images. For some reason it’s not recording videos.
    More info to come.
Any update? Thanks!!
I am also having this issue. I thought it was the device so I bought a new one and it worked for about 2 weeks, now getting this every time someone triggers it.
WYZE sucks. They know they have problem and they don’t fix it. The FIXING that some useres are providing is at the least funny. In the 90’s maybe the solution was REBOOT. In the 1990’s. Wake up WYZE to 2023.
Taking the battery out of the camera is not a desirable option when you have to do it several times a week, and they require a ladder to get to them. This is a widespread problem with the Battery Cam Pro. Every one of these I have purchased has had the same problem, starting with intermittently, and now permanent. I bought them less than 6 months ago. What is Wyze doing about this problem?
I’m getting Error: (code -5) all of the time now on my old android device. I had to install a previous version of Wyze on it, which worked for several months (2025-2026), but recently I updated the firmware on the camera (v4). Since then, I always get the -5 error on this older android device (running android 8.0.0). The connection to this same camera works fine on newer devices (android, ios, web), but I thought I would post in case anyone had suggestions for how to get this working on my older android (our dedicated monitor). Thanks in advance!
The latest public firmware for Cam v4 is incompatible with Wyze app versions older than version 3.8.5. And app version 3.8.5 is incompatible with older Android viewing devices. I.e., if your Cam v4 is loaded with firmware version 4.52.9.5332 and you can’t update the Wyze app on your old Android phone/tablet to version 3.8.5+, the only way you can view your Cam v4 from that device is to either flash your cam’s firmware back to an older version or attempt to view the cam via Web View using a browser on your phone/tablet. I’m not sure about this, but there may no longer be any option to view Wyze cams under Android versions older than Android 9. I gave up trying to get an old Wyze app working with late model Wyze cams under Android 8.
Ref: https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware#Accordion-wyze-cam-v4-firmware-37
Wyze Cam v4 Firmware
4.52.9.5332 (December 3, 2025)
  • Security Improvements
Note: You will need to update the app to version 3.8.5 or above to receive this firmware update. App versions lower than 3.8.5 can’t connect to this firmware due to security improvements in both the app and the firmware.
Note: This firmware will be released gradually over the next few weeks.
