I get same notifications twice ! How can i fix this?
I can think of at least 3 different situations that may cause this, and they all have different explanations and ways to resolve it. Can you post a screenshot example so we can get an idea of what the cause may be?
If not, are they all EXACTLY the same notification? Or are they a notification for the same thing, but maybe labeled differently (one says motion, one says person; or one says motion and the other says sound), or if they’re exactly the same, do you by chance have more than 1 duplicated Wyze app loaded on your phone in some way? For example, do you have the production Wyze app installed from the App store and maybe a Beta app from Test Flight or something?
What app version are you using and what is the firmware version of the camera doing this?
I’m having the same issue, started this morning sometime. Running the latest non-beta app version and it hasn’t updated since last week, so it isn’t related to app version, and I haven’t made any changes. Tried clearing cache on the app but didn’t help.
Odd, I think it stopped, some weird bug related to February 1st or leap year or something?
Can confirm this bug only happened for me on February 1st. Some weird date related thing. Been getting single notifications since.
Double notifications stopped today.?!
Wyze fix?
Or is it because I change my iphone notifications for Wyze app to automatic grouping?
A mistery….
As I mentioned above it only happened for me on February 1st. Some sort of glitch with the date, or maybe something to do with this being a leap year. I’ve seen glitches with notifications in the past (like the time being off by several hours) which were resolved by reinstalling the app. But this one resolved on its own.
Single notification when App closed and double notification when in App.
What could cause this?
Go into the app settings, my guess is you have both “in app notifications” and “push notifications” enabled?
It’s back again. Must be a wyze service side issue, because I didn’t change anything.
I’m getting the same thing. One clip shows in my notification, but I get two chimes.
It’s a bug that seems to come and got with no rime or reason, at least on one of my v3s.
Yeah been that way for a long time, I’m used to it. I did pick a system sound that is a bit less intrusive than the Wyze options but still audible enough to alert me.
Same issue. Any fix for this yet? Using android.
Are you getting double notifications or just 2 sounds for the same notification?
If the latter, no, there is no fix. If the former, there are some workarounds to disable “other motion” and “other sound” so you only get the smart/AI notifications.
There seems to be a new bug (only affecting cam plus subscribers) where the notification first comes in as “general motion” then changes to “person” or whatever. I believe the current workaround for that is the same as above, to disable other motion alerts.
Running older app 2.50.7 (487)
Started getting a double notification sound too, but only on a shared camera (me being the shared user).
All cams on my account get single notification sound.
Just another Wyze bug on the list ![]()
I’ve been getting double notifications for months now, sometimes I even get 3 notifications for the same event. It’s beyond annoying! So much so that I had to turn off notifications for all my Wyze cameras. Doesn’t seem like Wyze is even attempting to fix this issue!
Their asses grow perpetually wider.
Happening again. No changes have been made to the settings. Since it started.
