I have a Wyze Doorbell (FW 4.25.1.060) and a Wyze Chime (FW: 0.0.0.21)
I have set the chime schedule to “All day” but after a while, the chime does not work anymore when someone rings the bell. Checking the schedule settings: It’s always set to a random Start time and End time and the “All day” switch is disabled.
Is there anything I could do to fix this from my side or is this considered to be a bug?
Try clearing the app cache in account > app settings. Then force close the app and update all the settings. Also make sure the device and app are up to date. See if that makes a difference.
Hmm, since it doesn’t look like anyone else chimed in here, best is to get a log and give it to support. To get a log, go to the device > settings > Wyze support > submit a log. Then contact support and give them the log number. Thanks!
I currently experienced similar issue. I have updated both Wyze doorbell and the chime to the latest available firmware. I also have tried to delete the Wyze Doorbell and re-added it again. Unfortunately, nothing has working.
My current workaround: I check the app daily and if the settings have been changed I just set them again. Very annoying! I hope this bug will be soon fixed! As you said: the doorbell is useless with this bug!
I have a usable workaround now. If you have Alexa, you can create a routine to play a doorbell sound on the speakers when the video doorbell button is pressed. Hope this helps someone. Please fix the chime!
We’re having the same problem. I have tried unplugging everything and re plugging in and I even tried factory resets on everything and then repairing and the issue still persists. What’s the point of a doorbell if the ringer isn’t reliable?
Fix your garbage product Wyze! We are missing basic functionality here!
I love how they closed my ticket too!
You have replied to a closed ticket.
If you need help, please visit our Wyze Support site https://wyzelabs.zendesk.com/hc/en-us and click the Support button on the bottom right. You can use it to troubleshoot issues, browse our support content, and contact our Wizards team to create a new ticket if you still need help.
Same issue. Been happening for months. Chime schedule resets itself from the All Day setting I select. It works immediately after setting All Day, then… sometime… magically reverts to 7:24 PM to 7:24 PM… which, even if that logically would make it a 24 hour chime, disables the chime.
