Hi Folks, I am contemplating acquiring a Amazon Echo Hub, however before doing so I am using this medium to ascertain whether the Wyze v3 camera and the Doorbell v2 is compatible with the Echo Hub
All replies will be greatly appreciated.
I believe @R.Good uses an Echo Hub with his Wyze stuff, so I’ll call him in here to comment.
I use Echo Shows and they work great with my Wyze stuff.
Just diving into it… I can give more of an overview in the next couple of days.
When you say compatible, What are you looking for?
I can tell you that the Doorbell v2 and V3 Cameras are able to be streamed on this device.
Hi Good,
Thanks for the timely response to my inquiry. I am seeking to ascertain whether I can use the Amazon Echo Hub to view video etc from both the Wyze v3 camera and v2 doorbell.
Hi Carverofchoice,
Thanks for your timely response to my inquiry it is greatly appreciated and I am in communication with @R.Good.
Hi R.Good,
Thanks for the feedback it is greatly appreciated.
Does the doorbell view show up automatically if someone rings the bell?
No it doesn’t!
ah that’s a shame, might be a dealbreaker for me
Not out of box, but you can setup a routine in Alexa so when the doorbell is pressed it will show you the video on the Hub.
And Welcome to the forum @nkonstantakos!
Hi R.Good,
Thanks for the info it is greatly appreciated.
Oh excellent – thanks for that. I just got mine yesterday…I’m not sure how I feel about the lack of configurability with some of these widgets. Am I just doing something wrong or can you not actually choose what your own favorites are in the favorites widget? ![]()
Edit: Seems like you can actually modify the favorites in the Alexa app, but it doesn’t let you favorite routines. I just feel like I should be able to have all the scenes I typically use in a room right next to the light controls…
Yea, it’s all setup in Alexa. Def needs some improvement but its a solid start.
This is how I was expecting the Echo 15 to be, but it was a let down.
