I would also be interested in testing 1.0.8 as I’ve had the same issue. Log ID: 510012
I would also like to be added to the white list. I can run Quick Runs all day long, buy my schedule says it should have started at a specific time, but the zones do not show on in the app, nor are they on.
Thanks
@Shanee schedules have worked perfectly for 3 days now with no device restarts and quick app runs work as expected since switching to the 1.0.8 beta firmware.
Thank you!
Please add me as well. Log ID 482991
I think at this point it makes more sense to release the new firmware to everyone instead of allowlisting everyone on this thread.
@Shanee, again my drip zone ran this morning and did not shut off at the end of the cycle. I had to manually turn it off via the app. Submitted log 511725
@ywijting @kellen.madsen @PeterF @matthewskyle63 I added you all to the whitelist.
(Reminder - you’ll need to be in the beta program, which is easily done: go to Wyze app > Account tab > About > Beta Program > Enroll and select Sprinkler. And make sure you’re on the 2.29 app)
Thank you, Shanee
Yorick
Also, they need to make the update’s default duration be something like 5 mins for each zone. It is currently 45 mins as default and that is soo much water if you have 8 zones going.
I have two zones… and if I ran them for 45 minutes per zone… my HOA would send in a swat team if I wasted that much water every other day…
Might be better to default to a shorter time than a longer time.
SJ
And my scheduled two zone, 10 minute run completed successfully last night at 1am
I’ll assume no more logs need to be sent up at this point unless something breaks again.
SJ
That’s scary… if this happened to my system, where I water at 1am when I’m sleeping… I hope that never happens to my system !
SJ
I am on the beta 1.0.8, and my schedule failed to run the last two days.
The beta is still not a proper fix.
Please ensure engineers keep working on issue.
Sorry to hear yours is failing. I just checked my Sprinkler Controller on 1.08, and it ran my two zones last night successfully.
Hopefully Wyze gets to the bottom of this. Be sure and send them Logs when you have the issue, and post it to them here.
SJ
I noticed my "
previous" watering on the main screen does not update… But it did water as schduled
Hi,
I ran the beta test and my MWF irrigation schedule went off the first two times (Friday and Monday) but did not run today (Wednesday). My log number is 514662
Thanks,
Jessica
@alcamino19 If you could submit a log and provide the #, that will be very appreciated.
@gregbambino Thanks for letting me know. Is “previous watering” still not updated?
@jessiegray0725 Could you submit a log once more and double check for me if “Send log files” is selected? Thank you!
Correct. The sprinklers run, but it still has a date from February
Still not working…
@alcamino19 Thanks for letting me know.
Could you submit a log and provide the # here? This will help us find the root cause.
