Can't access any of my cams. My Wi Fi is up as I can access my video doorbell
My cams are located in Fremont, CA and up until about an hour and a half ago, I was able to connect to them.
Mine are also down in Alabama. My wifi thermostat is working no problem. so wifi isn’t the problem
I wish they had an outage map or outage alerts
Glad I’m not the only one experiencing issues. Thought maybe my wifi or power was out, but I was able to connect to the my thermostat and remotely get to my router.
Down in Nebraska. Another round of the (error code: -90) errors.
I am getting error code 27
See this:
Error Code 27 on all three cameras out here in Scottsdale, AZ
Another bay head :raised_hands:t5:
2 of my 4 cams won’t connect correctly. My wife is able to view all 4.
Can’t view any of my 4 cams here in TX.
Same for me in VA can’t view any cams; and they are at different locations so it def isn’t the WiFi.
https://forums.wyze.com/t/connectivity-trouble-1-17-19/15539/2
Known issue
Same issues in Michigan. Events record though.
Chicago here checking in with inoperable cams in two completely different systems in different houses. Looking forward to a quick remedy as I am entertained daily as to what these things capture.
