Battery Cam Pro missing most events
Recent install of battery cam pro pointed towards a driveway and it is missing 9 out of 10 events. What I’ve done so far: deleted and reinstalled cam, adjusted sensitivity to max (6), max distance, tried it with and without detection zones…I know the firmware is in its infancy but I was hoping for a little more accuracy in detecting events. Also, mounted as recommended about 7ft up with a slight angle down…thanks in advance for any help
What kind of events are you looking for? Person, vehicle, pet?
How far away is the camera to the far side of the driveway?
Do you have a cooldown period set?
If you’re able to upload a screenshot of the view, we might have some other ideas of things that could help.
