That’s my question. I already have two V3s in my Cam Plus Lite (CPL) subscription. I found out the hard way that my OG and V4 would not work with CPL. I want to know if there are any “gotchas” before I buy another V3?
Thanks!
Thanks!
As long as you have an existing subscription, yes, you can add as many v3s or earlier as you like. Note the Panv3 is NOT - only the regular one.
However note that some people have noticed that their subscription end date has changed to 2027. Whether this means it will be discontinued next year or if they just changed the way it displays (renews every year), we are not sure. But something to keep in mind.
I will add that my Cam Plus Lite service was listed as renews in 2072 last year. Why change the renewal year to 2027 if Wyze plans on letting grandfathered users continue using Lite for a long time?
Just checked my subscription and it does indeed say Dec. 19, 2027 for renewal date. Going to be very unhappy if that truly means it expires then and won’t renew since Wyze promised to keep it for us.
Everyone’s date is different (though they are all 2027) so I don’t think I’d panic just yet, especially since it says it will renew at $0 on that date…
I believe @carverofchoice is going to try to get some confirmation from Wyze.
