I have 11x Wyze Cam OG & 1x Wyze Cam Pan V3 all on basic mode (no subscription) being monitor via IOS and Android app but the Android app keeps on crashing on me. It only started to happen recently when I introduced from 6x cameras to 12x cameras. Wyze App Android is version v2.50.7 (487) and I am using Samsung A51 software One UI version 5.1. Appreciate your insight please. Many thanks
I don’t think that’s the problem. I have 50+ Wyze cameras and 300+ Wyze devices total on Android and mine doesn’t keep crashing, even on my Samsung Note 8 with the 2.5 app version.
Try uninstalling the app and reinstalling it.
Will give it a go, thanks.
Let me know when your cameras want to visit goodwill?
haha, the nice thing about cameras is they are so versatile. You can even use them as something as simple as a motion sensor or other kind of binary sensor. I could probably find uses for a hundred cameras as sensors in various ways. They can also be used to do totally custom detections (with an RTSP stream and fancy things like Frigate or Scrypted doing custom detections). Plus various timelapses, meteor watching, and countless other things, etc.
I have some doing REALLY niche stuff nobody else would care about. I have some setup to be able to make sure there are no cats anywhere near my cat litter robot before it cycles to clean their litter, then if any appear, it can shut it off before they ever see it move, etc.
However, I did give some away to my uncle and my brothers when they needed some, as I upgraded.
Luckily my Mesh WiFi is pretty solid. I can handle a huge WiFi load really well. Never had interference issues.
Re-installed app and I seemed to get more notifications since then but it still crashes
