Alexa Routines Not working
According to this web page: https://support.wyze.com/hc/en-us/articles/360048472832-Use-Person-Detection-with-Alexa-Routines?utm_source=braze_canvas&utm_medium=email&utm_campaign=SEG-43+|+Cam+Plus+(Free+Trial+Flow)+-+GROUP+A
I should be able to use motion / person / car detection as a triggers with Alexa. But when I do step 5 it says “Error” “this device not supported”.
Do you have camplus on the camera you are trying to create the routine for? What camera are you setting up the routine for?
That webpage and the routine setup only mention “person detection”. Person detection is not vehicle detection or regular motion detection. Wyze cloud ai tagging is all of the above, but saying “person detection” is not for all of the tagging, just tagging people.
Yes I have cam plus on all my cameras. And I have Version 3 cams.
Do you have the “Wyze Skill” enabled in Alexa already? if you do, id suggest unlinking and relinking it up, If you don’t, Id suggest installing it.
I do have it installed.
So I removed and re-added.
I take it that it works for you.
So now I am wondering if it is somehow country limited?
Normally if a skill is not working in Canada we just can’t add it. But the fact I can add it appears like it should work.
All the best,
Joe
I watch the “Automate Your Life” YT videos. In several of his, he comments how Canada Amazon customers can’t use some features. I believe that’s your issue. There’s a work around that he has used. He changes his country in his Amazon account to U.S., logs out and back in.
I am now starting to think the problem is that the Person Detection with Alexa Routines is only something you can do on the doorbell and not on the Wyze Cam V3.
But the answers I am getting from Wyze support aren’t making a lot of sense to me. They said I don’t have a person detection licence but I do have a cam plus licence?!?
Not making any sense to me unless another type of licence other than Cam Plus exists.
It is definitely a problem in Canada. I have placed a ticket in November 2020 with Wyze and another one recently, but I don’t think enough people are reporting the issue for them to spend any time on fixing it for Canadians :frowning:
If you have the same issue - please place a ticket with them.
Two different things. Person Detection is a legacy product available for users who had V1 and V2 Cams and elected to “pay what you want” for the service which was included originally for free. It is the precursor of CamPlus.
I have the same problem. Wyze could not help me after many iterations. Even tried different support tickets. It is like they don’t even know it is a problem. It is a shame they haven’t made the effort to correct this. I’m disappointed as i have 5 cams all with cam plus and 3 echo shows. :confused:
Hey Wyze engineers, when will you make this work for Canadians?
How about some support for Canada? We’re paying the same subscription fees but are locked out from a lot of features… how does that make sense?
Was it working before? I am not familiar. Have you been able to run routines before with a Canada account?
(I have a suggestion. Create a new account on Amazon and assign the country as USA for your routines. Be sure to set the Wyze skill to use this account. Or, change you current Canada account to USA, and change nothing. You can always create a new Amazon account for your Canadian Amazon purchases.)
Routines never worked and have been reported for years to Wyze.
I don’t even want to think about what’ll break in the Amazon ecosystem locally for us if we change the country.
I will end up switching away from Wyze for the devices and subscriptions when I get that annoyed.
I am Canadian and running into same Error…This Device is not currently supported.
Funny though, Last Year I was able to use my Wyze Cam v3 to trigger Routine when It Detects a Person. And they are Still Working Fine. Note, I do have CamPlus
Problem is I can not create any New Routines or Modify the Timing on my existing Routines.
Wyze has not been helpful and so far Alexa is saying Wyze Cameras are not Supported.
It’s annoying, and the current work-around is to give them a little more money:
You buy a Wyze smart plug (I am using the outdoor one because it was on sale) which you trigger in a Wyze rule to turn on when a person is detected.
Then you can run an Alexa routine that is triggered by that state change, then does its thing and then turns the plug off again … or runs other things that ultimately turn the plug off again , once you are ready for another trigger.
Home automation can be mind boggling. For the lights on our front door/garage I am using Wyze, Alexa, Google Home, IFTTT, our garage door sensor, switchur, and some webhook integrations for Alexa.
Just to turn them on and off with person detection, garage door open, geofencing and the ability to override the timer locally. And it’s almost there :unamused:
Hey Mark, thanks for your response and Ideas.
Yes, very anoying. I am ok for right now as I do have a couple of old working routines already making an announcement on my speaker , and turning on light at different times. But with the Night Time coming earlier, it won’t let me change the timing on those triggers. And I want to add another Camera in the Back but pretty sure I won’t be able to create any new routines for that.
They claim Alexa Support but pretty useless without the routines as far as I can see. I did see a post that you can use a few third party apps but looks pretty complex. I might try it, but I’m thinking I might be shopping for another System.
I hear Eufy can do the Routines pretty well.
Not finished trying to push this for all Canadians yet, but so far not getting anyware .
Have a good Christmas.
Cheers Bert
@BertAgos, Just a suggestion to test with. Create a new Amazon account, but set the country to US. (Yes, I know you can change yours to US to test with, but this may have hooks that don’t expose themselves.) Then add the Wyze skill to that US version account and check to see if your routines work.
For what value it is, my US routines are and having been working fine with Wyze cams. And yes, I used the person detection to trigger a view to display on my Echo Shows.
Hi BertAgos
That’s actually where the Wyze plug workaround has an advantage over straight Alexa integration. You can set in the Wyze rules to only trigger between sunset and sunrise - something that Alexa routines still can’t do.
Wyze, Google Home and Smart Life have day/night conditions, but Alexa still not…
I am well aware that I am resurrecting an old thread, but looks like the Alexa routines still not working with Wyze cameras.
I’m trying to set a routine that when my V4 detects a person to turn the Kasa bulb for 15 minutes. When I select the V4 all I get is this "Error: This device is not currently supported. What gives? :thinking:
