After Firmware Update yesterday & Now SD cards aren't working
I did the firmware update yesterday (1/3). Today (1/4) going to check my 5 v2 cams. Only one seems fine. The other 4 stopped recording to my fairly new SD cards on Feb 2 just after 6:40pm. And still getting a cam showing offline which was my constant issue prior to this firmware update. Restarting router fixed that a few times a couple days ago but always came back. Today I have now power cycled all cameras and restarted router and same thing but 2 camera seems to be working (3 still not recording to sd). The offline went away. Firmware Vers 4.9.9.1851
Any ideas? Thanks
submit log to Wyze. if you habe done so.
check Wyze News forum on this new firmware.
Yes, I have submitted a log. I will see if i can find the news forum. Thank you
I also didn’t get notified of your response like I usually do when I post. I checked setting and they look fine also. strange
Same here. I’m traveling and my home is now often unprotected without my knowledge.
After updating to latest camera firmware continuous recording randomly just stops.
All I can do is remotely restart cameras and reformat SD cards. Those actions sometimes resolve recording issue but then it will just randomly stop.
What size SD cards are you all using? I’m using 32GB and the cam resumed continuous recording after update without issue.
I have 64GB. It seems to finally have sorted itself out but took time messing with it.
I have 128GB Sandisk cards that were specifically designed for continuous use video recording.
This issue appeared right after updating to the latest firmware. 4.9.9.1851.
So just after spending hours the other day finally getting cams to record to SD card. One more went down yesterday again😒
What model camera did you have the issues with so we can see if we have the same issues thanks
I stated them in the original post. They are v2 cams
Great we gave all of ours to the church
V2 Cams here also.
They just randomly stop recording.
Both of my V2 cams have quit recording after updating to 4.9.9.1851 as well. Both have Samsung pro endurance 128GB cards installed.
So it’s not just me, my V2 stopped recognizing my SD card in the last month or so and I figured it had just died. I’ve tried ejecting, formatting, nothing gets it to recognize. I believe it’s a 32GB Sandisk that was set to only record on motion
My V2 cam has also stopped recording to the SD card running 4.9.9.1851. My other V2 cam running 4.9.9.1851 is recording normally.
Any help?
I’ve essentially given up that this will ever be fixed. I also suspect that it might be a failed SD card, but I don’t use the camera enough to buy another one as an experiment. Sorry!
Have you found a solution for this issue? I have been having it a long time for all 5 of my v2 cams. Randomly of course. But the sd cards have quit rewriting over when they get to the end. They just quit. I go to look at a camera and there is no playback. I have replaced and replaced my sd cards with different brands, sizes. Doesn’t matter. They seemed to work fine the first year or so. When all these various issues started happening (and there have been alot), especially the sd card issue was when they implimented charging people. I literally have to reformat everyone of my sd cards when it gets to the end. They won’t rewrite ever anymore.
what firmware version?
try early 4.9.8.1002
If that question was for me I have the most current firmware. 4.9.9.2351 How do you get the old firmware?
