Ability to Manage Licenses Assignement
I have a unlimited license plan… I have 20+ cammeras but I don´t want all of them to have the license. I want the posibility to assign and un assign licenses to cammeras.
I have already payed the unlimited so I don´t see how can this impact Wyze.
curious as to why you don’t want to include all cameras on the unlimited since you have them available?
I constantly move the cammeras from one place to another, depending on where they are installed I don´t need the license. I´m preparing for the future, depending on some work plans I will need to have more than the 99 and not all with licences or move the licenses around.
I will reach out and see if this is something that is possible. I do know that they get added automatically. But not sure if they can be removed.
Will find out and let you know
Thank you for your help! I will really appreciate the abilitty to manage the licenses for my cammeras.
Although I am not a Wyze Employee, I am a Moderator. I have reached out to see if I can get a response. I also provided a link to this discussion.
It is my pleasure to help out. Will let you know what I find out.
They can’t. I had both Unlimited and Lite and you couldn’t remove cameras from Unlimited.
Yea, I believe it is expected that if you are on Cam Unlimited, then the cameras can automatically be added to it. When it was Cam Plus, you could remove them.
I am checking to see if something can be done.
I would also like to be able to do that. I have asked the question on another post as well @carverofchoice asking at the recent AMA. All we got was crickets from Wyze.
Has there been any update on this matter??
Not that I am ware off. Still waiting…
I wouldn’t hold my hopes too high though!
