2.50 App Beta Test 2/13/2024
Versions:
  • Android: 2.50.0.b404
  • iOS: 2.50.0(3)
What’s New:
  • Added support for Wyze app login using Facebook
  • Added support for snoozing Event Video notifications from a notification (Android)
  • Added support for using long press to snooze Event Video notifications (iOS)
  • Bug fixes
Same problem as I reported with the prior beta, deleted events not being removed from the Events screen, user needs to manually refresh. It seemed like it worked correctly the very first set of deletions, but never after later deletions. Disappointing there is no detail in the release notes as to which bugs are fixed, and that this bug should be pretty trivially easy to fix.
Loaded on iOS. Waiting for Android to be available.
Using iOS, notification previews seem to be broken on this build.
I still only have Android 2.49.3 (399)…
And that was actually offered for download later on the 13th… So I thought I was getting this one…
The Android app is still under review by Google and we hope they will approve it soon.
Thanks for the update.
Beta app 2.50.0.b404 for Android was just released in the Google Play store. Note that version is different than topic’s 1st post (b401).
Thanks. Just installed.
Snoozing events from notifications. Interesting.
Yep. Frequently requested feature with a wishlist topic somewhere. I’m testing it now.
Update: 10 minutes snooze at the device-level from notification is working well so far. :+1:
The mute cam for 10 minutes and mute all for 10 minutes via notification is working well. Perhaps not for this release, but need to give thought into how we can cancel these mutes before the 10 minute expiration.
Android beta app b404 seems to have notification issues with the Wyze Lock. Log Submitted: 1324877
I am receiving notification from the lock on my Samsung running the prod app and my iOS device running the beta app. So it appears to be limited to the Android Beta App.
@WyzeJasonJ @WyzeMatt @WyzeAndy
@carverofchoice confirmed that the Wyze Lock does not notify on lock and unlock or open and close.
App Beta v2.50.0.b404 and SD Playback mode
I see the Beta version is a little better and the Playback button is not greyed out anymore.
But there are still a few quirks that prevent playback.
I see the event when tapping “Recent Events” but there is no way to playback from SDcard. I have to then scroll down till the end of events and then have to tap on “All Events”, then I see “Motion” for the event and a prompt to get Cam +. I should be able to see motioni s available for the event when just tapping on it, not scrolling down to all events and tapping that.
The playback icon is now visible and not greyed out…BUT
When I tap on it, I get the message “MicroSD Card not found” and a prompt to buy an SDcard from the Wyze store.
[Mod Edit] I have a class 10 card in there and can view video “manually” by tapping the SDcard Icon and scrolling through the memory. Why can’t the app find the SDcard when tapping on event motion?
I see the same and will post some Log IDs this afternoon.
I’m new here so just understanding how the forum and company works.
Let me know if you want me to test anything on my end and send logs
Thanks
Phil
No problem. :+1: Please send logs and post the Log IDs here in this topic. Make sure a brief problem description and optionally a screenshot accompanies each log. It’s the best way to expedite bug fixes in beta versions. Developers usually don’t have time to respond to our submissions here in the beta category, but they do look for our reported issues.
Is it a running log file that I can clear out so I don’t send them tons of data and make them look for timestamps and stuff.?
There is no running log feature. Just send a one-time, static log from the Wyze app after hitting the bug. The easiest way from a beta Wyze app is to enable the floating Submit Log Button: Wyze app Home > Account > App Settings > Submit Log Button > toggle On. Make sure the “Send log files” checkbox is checked before hitting the “Submit” button when you submit a log. After submitting, the Log ID for your log file will be displayed. You’ll also receive an email confirmation with the Log ID. Alternatively, you can follow these instructions: How to Submit a Log. When you submit an app log, there is no follow-up by Customer Support. The log file goes straight to the dev team. We post here in the associated beta version topic to help draw attention to the issue with supporting log file IDs.
